  • July 03, 2025, 11:58:41 PM
Author Topic: "End of the flight" Question  (Read 2185 times)
Offline Joe Messinger
« on: July 07, 2006, 04:32:11 PM »
My P-40 profile does just fine until the end of the flight.  It then "stutters" through about ten laps before the engine finally quits.
It's powered by a FP .40 with muffler pressure.  The tank is a plastic 3 oz. Sullivan with a klunk.  The klunk appears to be working as it should and I have checked for air leaks in the system and found none.
As I mentioned, the thing runs smoothly until the fuel is about gone then it falters and revs back up repeatidly for 8-10 level laps before the engine stops.  Not a big problem but pretty annoying.
Anyone have an idea (ideas) as to what the problem might be?
Thanks ,
Joe
Joe Messinger
Offline Roger Vizioli
  • CLiner
Re: "End of the flight" Question
« Reply #1 on: July 07, 2006, 05:00:39 PM »
 ???      Just Some thoughts-
Flex tubing in tank too stiff, wont move to outboard side.
Clunk weight/pickup too far forward from rear of tank.
Flex tubing inside tank has a slit/break .......
R....
Roger Vizioli
AMA L-2408
Florida/Space Coast
« Reply #2 on: July 07, 2006, 05:12:10 PM »
use a sintered brass clunk/filter....not an RC clunk....
like this one.....
it removes bubbles, and gie you the cleanest cutouff you can possibly get with a clunk.....
« Reply #3 on: July 07, 2006, 05:34:25 PM »
Hi Wynn,
Thanks for the advice and photo.
I'll give that a try tomorrow as I'll be going to Brodak's to fly.
I've checked everything else and it appears to be okay.
Joe
Joe Messinger
Offline Dennis Vander Kuur
« Reply #4 on: July 07, 2006, 05:40:26 PM »
Joe,
Are you using the stock remote needle valve setup? I had an OS FP .40 do exactly what yours is doing - cutting in and out for 6 to 10 laps before finally quitting. The fix was to remove the remote needle valve assembly and then install a spray bar and needle valve at the venturi. Now I get a single burp and one lap later the engine quits clean. Hope this helps.
DennisV
Dennis L. Vander Kuur
AMA 29292
Offline Greg L Bahrman
« Reply #5 on: July 07, 2006, 06:04:24 PM »
like this one.....
Where do you get these??
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Offline SQ8s
« Reply #7 on: July 07, 2006, 06:18:48 PM »
If you make it through the pattern and then runs bad ...I bet it's the height of the tank and or the clunk not long enough.
But after the flight..........?? ~^
Scott Riese
Offline Sam Laughery
  • ACE
    • laurelhighlandsrc.com
« Reply #8 on: July 07, 2006, 06:45:50 PM »
Hey Joe,
I'll be at the field tomorrow about 2 or so.  I've had some similar probs with clunk tanks.  Maybe I can help.
See you tomorrow.
Sam
« Reply #9 on: July 07, 2006, 11:04:29 PM »
My RNV equipped OS .25LAS does the same thing, with a metal tank, no uniflow. Next time out, it won't have a RNV, and I don't think it will act the same. I also will be changing the tank to uniflow, tho. That will require height adjustments, but the run starts out quite rich and ends up a bit lean, so it's got to happen.  :!  Steve
Offline Tom Perry
« Reply #10 on: July 07, 2006, 11:16:39 PM »
Joe,
One other thing to try is shimming the tank so thr rear is about an eighth of an inch farther to the outside.   #^
Tight lines,
Tom Perry
 Norfolk, Virginia
