Hi Dan,
Good question, but a hard one. Per AMA, most maneuvers are to be flown at 45 degrees (triangles, loops, etc.) or at 90 degrees (verticle eights, hourglass, etc.). In the case of a triangle or hourglass, since the triangles are to be equilateral triangles, I think that means if you were to look at the control line circle from a birds-eye perspective, the width of the triangles and hourglasses would be like taking a 45 degree pie slice out from the circumference of the circle.
To further compound the issue, the width of a triangle or hourglass will naturally be dependent on the length of lines you are flying with, since these will affect the circumference of the flying circle and thus the "width" of the maneuvers. There would be quite a bit of difference in the width of the pie slice if you were flying 60 foot lines compared to 70 foot lines. Technically, every little increment of line length difference will change the circumference of the flying circle. Doooink . . . my brain is already starting to swim
All these maneuvers crammed on to a single 8.5 X 11 page doesn't leave much room for "marking up". I think the most important part of critiquing is marking up areas where the 45 degrees height was not met, where corners are not 90 degrees, where circles are not round, where anything overhead doesn't bisect the circle and where you have overlapping maneuvers or missed intersections. I think adding more factors to the critique sheet might take away from the area where you need to do the markups.
We have rocket scientists, engineers and very experienced judges on this forum who could probably explain this a bit better, but I don't think the critique sheet is some magic thing where you can instantly start flying better. My guess is two judges critiquing the same flight might not see the exact same errors as each other. Like I mentioned earlier, I think the best use of this tool is doing your markups while watching a video of the flight so you can go back and forth on the video looking for all the errors, though certainly there is some value in having someone markup the sheet while you are actually flying - better than nothing.
If someone has a good way to improve this sheet, I am happy to make changes, but we need to be careful about the sheet getting too confusing. I will certainly post a few of them after this weekends Stunt Camp. Good idea for those who may not typically use these sheets. We will be doing some video as well, so maybe I could have one of the judges critique the flight in real time and then critique the flight using video. My guess is many more errors would be found after critiquing the video.
Good question.
