  • June 14, 2025, 11:11:09 PM
Author Topic: Pat Johnston's Epiphany  (Read 1395 times)
Online Mike Griffin
« on: April 20, 2020, 10:36:58 PM »
This is a picture of Pat Johnston's Epiphany.  Has anyone built the glow version of it?   I think this is going to be my next build.
Thank you for any help
« Last Edit: April 21, 2020, 11:38:05 AM by Mike Griffin »
Offline John Leidle
Re: Pat Johnston's Epiphany
« Reply #1 on: April 20, 2020, 11:30:03 PM »
 Mike,
  Seems to me Pat had a Magnum .53 in his Epiphiny . Also another one around here  was yellow if my memory is correct might have  been owned by Dave Gardner had a Double Star .60 in it..
        John L.
Offline BillP
« Reply #2 on: April 21, 2020, 08:34:58 AM »
I don't know about it but what are the specs? It looks interesting. Where are plans available?
Bill P.
Offline Dennis Saydak
« Reply #3 on: April 21, 2020, 08:48:04 AM »
With a little tweaking of the rudder and some war paint it could pass as a Spitfire.
« Reply #4 on: April 21, 2020, 08:58:21 AM »
Pat has done several versions of this design. There has been a full fuse version and a couple of sizes of profile and a twin. Pat is fond of using the OS.46LA with a fairly small venturi rather large APC prop. I believe he used a Magnum .53 on one full fuse version. Not sure what else. Pat and I flew together for many years and he is clever designer.
You can order plans from Pat at patsplans@yahoo.com
« Reply #5 on: April 21, 2020, 10:11:27 PM »
 Good looking design. Redraw the vertical fin and you've got a Spitfire.  ;D
Online Mike Griffin
« Reply #6 on: April 22, 2020, 07:53:37 AM »
I have always like those elliptical wings.  It does look a lot like a profile Spitfire.
Online Mike Griffin
« Reply #7 on: April 22, 2020, 07:56:24 AM »
Hi Randy,
I will either use a OS LA.46 or a Super Tigre .46.  Don't know which yet.
Offline SteveMoon
    • www.ultrahobbyproducts.com
« Reply #8 on: April 22, 2020, 09:45:03 AM »
LazerWorks.com offers a laser cut short kit of this plane.
« Reply #9 on: April 22, 2020, 10:56:03 AM »
Pat also offers a laser cut short kit. Or did, anyway.
Online Steve Berry
« Reply #10 on: April 22, 2020, 02:24:59 PM »
For what it's worth, I do have CAD plans for it that hes sent me some 20 years ago. Freely he gave and freely I can pass on, u less of course he says "No."
« Reply #11 on: April 24, 2020, 08:06:34 PM »
The Epiphany that I saw was full fuselage. It went from Pat to Dave Gardner to Pete Ferguson, which is where I actually saw and launched it for Pete...at the old "Mattress Factory" parking lot site. As I recall, the plane survived that day's outing, but sometime later somebody (?) tried to do the pattern with a bad NV setting and it sadly became an Ex-Epiphany. Don't do that!  n1 Steve
Offline Dave Gardner
  • AMA 717
« Reply #12 on: April 26, 2020, 02:34:44 PM »
Yes, I had the Epiphany ('Piph', as Pat called it...) and it flew very well....and very pretty, too!  I had lent it to Pete, since he was out of airplanes.  At an earlier Stuntathon, Pete took off with a poor needle setting, but rather than fly it out, he attempted to continue the pattern.  I don't remember the maneuver, but the poor NV setting became a 'shut-off' setting.....at an untimely pattern location, and the airplane was disassembled with an abrupt meeting with the tarmac.  It was very well built, but not repairable!
I got the engine and tank...and other wreckage bits.....but never attempted to replace the bird.  Pat has plans, in AutoCad and .pdf formats, from a previous posting below.
Dave G.
