  • August 01, 2025, 08:22:15 AM
Author Topic: Nostalgia pattern  (Read 7248 times)
Nostalgia pattern
« on: May 29, 2016, 10:18:06 PM »
Okay, my search abilities must be totally horrendous.  I'm thinking of flying in the N30 category and trying to find the pattern to be flown.  I can't seem to find the exact pattern sequence the N30 category flies.  Can anyone point me to the pattern flown for N30?
Mark
Re: Nostalgia pattern
« Reply #1 on: May 31, 2016, 10:22:57 PM »
Thanks!  I'll start my learnin'  Maybe I'll be halfway decent in a year or two...
Mark
« Reply #2 on: June 01, 2016, 09:55:45 AM »
Mark
Hey Mark, I've been at it for two and a half years and I'm about half way to decent, so there's hope Lol. I spent most of that time fighting with my unruly equipment.
Rusty
« Reply #3 on: June 01, 2016, 03:09:25 PM »
Rusty
Rusty that is what trips up many progressing pilots.  Less than great choices of equipment and the lack of knowledge to get what you have trimmed and working well slows the progress a bunch.  Getting good local help and maybe buying a couple 'experienced' airplanes from knowledgable fliers to learn on can help really get you down the road.
« Reply #4 on: June 01, 2016, 03:33:25 PM »
what Dave said,, there is no substitute for a good flying plane when it comes to learning , a less than good airplane will only make learning harder
« Reply #5 on: June 01, 2016, 07:16:01 PM »
I wiill stick my neck out and say , grab one of those nasty FAI Combat Wings , put the motor ( a good .15 on up , a OS FSR 25 wouldnt need Fwding )
and throw 55 ft lines , or 60s with the 25 on , and youve got a groovey , accurate flying F2B pattern Ship  for 50 bucks ,
thatll stand going in vertical on anything but baked clay or ashphalt .
The Bonus is , if you take it out in the wind , or ' scratch the paint ' it DOESNT MATTER ' . So you get good value practise , when you need it .
You dont use it ALL THE TIME , but for trying Anything New , or if the conditions are Alarming , you can chill out without stressing , and FLY .
If you wrapped a L.G. wire end to go about a engine bolt or two , you could r.o.g. .
Ive used a wobbly dolly from coathangers , like a speed dolly , with my stick in the ground handle , to fly Combat wings alone .
A lot just use a chilly bin with a THING on top , somehow , and step back , to pull it clear , for take off, and its OFF .
The ideas NOT to Risk or Destroy your works of art or labours of love in seeing wot way up the ground is . The FAI F2D are built from trash
in the first place , so its hardly heartbreaking if one IS trashed . You Fly it at the normal 5.0 a lap , + or - 0.5  calm or windy . So There .  H^^
