  • July 30, 2025, 02:11:04 PM
Author Topic: Brodak Cardinal.  (Read 11438 times)
Online Perry Rose
Brodak Cardinal.
« on: November 09, 2019, 06:43:18 AM »
Is it N-30 legal?
Online Perry Rose
Re: Brodak Cardinal.
« Reply #1 on: November 10, 2019, 04:51:47 PM »
Can the plane be built from the plans? If so could you copy the plans and send them to me? I have the profile plans so I only need the fuselage drawing.
« Reply #2 on: November 10, 2019, 07:56:31 PM »
GRRRH .
Theres  A 86 Cardinal , and a 92 Cardinal ' Tweener ' ( plans of which can be got from Peter White in W.A. )
Looke ere : http://library.modelaviation.com/ma/1992/11/cardinal-stunt-89
But wotcher wanna dois ;
Make a injun crutch , as per there , etc . Probably 1/2 x 3/8 bearers .
Throw in the rest of the bits around it ! .
he ' Big Jim ' Deflector ' V "ee on the Rogers patternmaster plan , is actually a Radius - Half the fuse inner width .Forward .
Out to outer edge at rear . With five 1/2 inch diameter outlets per side . Theser actually at the TOP of the DUCT . as ot air goes up ! .
Study the whole nose set up , A parrallelogram . essentially .
Look at the Big Jim Greenaway conglomeration in the N 30 part , here at S H .
Avva lookat this Fred : http://flystunt.com/AIRPLANE/Valkyrie.htm for de tails .
Theres also STREGA threads ( same animal ) and WINDY U Tapes on U Tube . One or three of which entails said Fuselage .
Go for the STREGA tapes , for that./ Initially . ( Some he runs 5.000 formers down the fuse . Well. a dozen or two , anyway .
As Per THIS . ( Another PATTERNMASTER Variation . ! )
http://library.modelaviation.com/system/files/styles/zoom1374/private/ma/ma199610/ma199610_046.jpg?itok=X5EjDxa8
From : Oct 96 http://library.modelaviation.com/ma/1996/10
The Big Jim set up requires a bit of incedance on the tailplane , or requires down elevator for equal turn . So its said .
« Reply #3 on: November 10, 2019, 08:42:45 PM »
BRODAK Cardinal July 2004 . according to this http://library.modelaviation.com/ma/2004/7/modelers-mall-200407 . tho its the A R T F .
« Reply #4 on: November 10, 2019, 08:46:41 PM »
ARGH . note the date .
« Reply #5 on: November 12, 2019, 08:35:40 PM »
This should be some help , https://stunthanger.com/smf/open-forum/my-first-crutch!!/
Some good Fuse. BUILD pictures . Its NOT the ' Cardinal 92 ' Oplan I have . States Cardinal Evolution 40 '
So may well be the device your'e after . Lot Less ribs than the bigger one, and seems the Thinner Wing .
Better count the ribs compared to the Brodak Plan , & see if it is the same one .
INDEED . Say ' 54 inch span ! . Crikey a G 51 in it. Would That GO .
