CLICK HERE--><--CLICK HERE
Brodak BY&O smooth finish props
Started by Wayne J. Buran, February 25, 2009, 04:34:35 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Wayne J. Buran
The Brodak BY&O smooth finish props are now in stock. Selected sizes are now available.
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
USAF Veteran 35 TAC GP/ 6236 CSG, DonMuang RTAFB, Bangkok, Thailand 65-66 North Coast Controliners   "A fine is a tax for doing wrong. A tax is a fine for doing well!
John Paris
Wayne,
How do they look and have you measured any?  Comparable to the RSM?
John Paris
269
Wayne J. Buran
John, I also just got some RSM props in also. They look close, however the BY&O still has a wider blade. The wood used looks differant, the finish is the same in texture but I havent measured the pitch. Eric Rule says that they spent a good amount of time developing the exact aerodynamics of the blade however you need to try both and compare. I have yet to see a "Super Prop" one design does it all. I compared the 10X6 props.
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
John Paris
Thanks Wayne.  I will have to keep some funds tucked away for the next time I see you.  Always good to have a new prop to test.
John Paris
269
