  • July 27, 2025, 08:35:05 AM
Author Topic: Linemaster 2.4 ghz  (Read 3577 times)
Offline Herb Reich
Linemaster 2.4 ghz
« on: April 18, 2025, 04:20:17 PM »
I read with interest the post by Carlos Diaz re development of the Linemaster control line handle. I participated in the Ringmaster event and the Linemaster would have been an excellent tool to be used in they this an event.
As such, I wonder if this handle is a available for purchase.
Offline Carlos Diaz
Re: Linemaster 2.4 ghz
« Reply #1 on: April 19, 2025, 12:46:20 AM »
Hello Herb!
I am still developing LineMaster 2.4GHz, i am in the final stages so you may want to take a look at our facebook profile https://www.facebook.com/profile.php?id=61560480371015.
I also started a web site where you can find more info and FAQs. here is the link https://linemasters-organization.gitbook.io/linemaster-2.4ghz
best regards,
Carlos Diaz
Offline bob whitney
« Reply #2 on: May 06, 2025, 10:37:40 AM »
Now throttle can be used with a mono line controlled ship , video's coming RAD
rad racer
Online Dennis Toth
« Reply #3 on: May 26, 2025, 10:41:22 AM »
Herb, could you design a simple light handle with just ON/OFF to allow 2.4Hz throttle shut down on demand for Stunt use? The current rules only allow 2.4Hz systems, having the ability to shut down on demand would allow for greater safety should some of us older flyers fine the need to end a flight or if there is any situation that could require ending the flight before the tank runs out. Ideally, having an idle start position that could go to full throttle then shut down would be great.
Best,   DennisT
Offline bob whitney
« Reply #4 on: May 26, 2025, 06:44:02 PM »
my big job has a line master shutoff added to it. Carlos is designing a hand held  transmitter that will shut down the motor i should have it at the nats.
rad racer
