  • July 31, 2025, 11:34:55 AM
Author Topic: Question about Primary Force ARF  (Read 17168 times)
Offline Jim Howell
« on: September 20, 2015, 12:17:19 PM »
Mike,
I obtained a PF ARF kit from an estate sale.  I suspect that this estate kit had been in a stash for years.  The fuse seems to be set up differently from the two PF ARF's that I got from a LHS, say, 5 to 10 yrs back.  The two previous ones had fuse's that allowed for an LA .40 to drop right in, mounting holes were right.  This new one seems to have a bit narrower engine slot and the holes definitely to not allow the LA .40 to be mounted, even if I were to open up the spacing between the mounts.  I pulled out a Fox .35 drill template, and it looks to me as if the fuse came prepped for the Fox.  So did the early versions of the PF ARF come assuming that a Fox .35 would have been used?
(Note, this is a curiousity question only.  I know what I need to do to use my LA .40)
Jim Howell
Huntsville, AL  AMA 545805
Offline MikeyPratt
Re: Question about Primary Force ARF
« Reply #1 on: October 04, 2015, 12:37:52 PM »
Mike,
Hi Jim,
I'm not sure what you have, but all the P-Force (kits & ARF) had the motor mount spacing set for Fox .35, LA .25, that I know of.  If they changed the spacing then it was for a spacing that would accommodate different engines.
Later,
Mikey
Offline Jim Howell
« Reply #2 on: October 21, 2015, 01:44:01 PM »
Hi Jim,
Later,
Mikey
Mike,
Got it, thanks for the response.  My apologies for my tardy response, I've been away and the various forums have had short shrift lately.  I would readily accept the F.35/LA.25 spacing.  What is a mystery to me is that I don't see evidence on the busted PF nose that I had inserted dowelling into the prefab holes and re-drilled new holes.  I must have, but it has been several years and several models since I set up my last one for flight.
Thanks, tho'.  And, I saw your response about short kit availability.  I'll get a check off to you.  Thanks.
Jim Howell
Jim Howell
