  • June 19, 2025, 03:21:22 PM
Author Topic: Up dated FORCE MK II  (Read 53850 times)
Offline MikeyPratt
« on: October 10, 2022, 07:35:46 PM »
The updated version of FORCE MKII, almost finished,  55 inch wing span, 610 square inch wing, larger 25% tail, plans will be available soon as soon as they are printed.  $35.00 shipped folded.
Re: Up dated FORCE MK II
« Reply #1 on: October 11, 2022, 12:34:47 PM »
Is there gpong to be an electric version?  Even though I haven't gone electric yet. D>K
Offline MikeyPratt
« Reply #2 on: October 11, 2022, 10:17:53 PM »
Hi Doc,
I was thinking that would be a good idea, it’s so simple to do I thought they could figure that out lol.  I may have to make a secondary plan sheet because there is no room on this plan to show how to convert it to electric.  As far as a power system, that’s pretty easy think to do.  It uses the same power package as the SS Banshee.
Motor: Cobra 2820 —-KV
Battery: 4 cell 2800 pack
ESC: CC 40 or 50 amp.
Timer: Hubin timer with adjustable RPM pot or Frottie timer
Prop: APC 11” X 5.5 or 12”X 6 prop
Line length C to C 61’ of .015.
Later Buddy,
Mikey
Online Mike Griffin
« Reply #3 on: October 17, 2022, 08:43:30 AM »
Looking good Mikey.
Offline Lyle Spiegel
« Reply #4 on: November 03, 2022, 07:53:26 PM »
Is design for .46?  What is source of the unusual bellcrank?
Lyle Spiegel AMA 19775
Offline MikeyPratt
« Reply #5 on: November 08, 2022, 01:29:26 AM »
Hi Lyle,
The Force can be flown with 40 to 46 glow engine.  Mine used the OS 40 FP and was great.  You could also us the OS .46 LA, one of my Force kit was powered by an ST .46 that flew it really well, way more power than a LA .46 and a much smoother runner.  The bell-crank is a SIg 4” unit that works extremely well, same bell-crank on the Primary Force and many other models I’ve buil
Electric:
That’s so simple to do and I did not have the room on the plan to show it.  Maybe I’ll make an secondary sheet for the Force to convert it to electric.
Cobra or Bad Ass motors
2026
4cell 2800 mHa pack
Hubin timer
40 amp ESC
11” X 6 3 blade prop.
Later,
Mikey
Offline B Johanson
« Reply #6 on: August 20, 2024, 06:45:18 PM »
Hello Mikey,
Did you ever get the re-design of the Force MKII and the E-Force complete ?  I know you ran into some ACAD issues a while back.
