  • July 06, 2025, 08:44:22 AM
Author Topic: VECO 19 Venturi Insert into R/C carb mount.  (Read 9401 times)
Online Dennis Toth
« on: February 17, 2019, 04:16:57 PM »
Jim,
Do you have or can you make up a venturi insert for a VECO 19 that had an R/C carb in it (See attached photo)? The stock venturi has a bore of  0.238" with a standard K&B NVA (0.158"), it has an outer diameter of 0.372", the distance from the bottom of the spraybar hole and the end of the venturi is 0.065", the distance from the top of the spraybar hole and the top of the flange is 0.104".
Please let me know.
Best,    Dennis Toth
« Last Edit: February 18, 2019, 07:12:10 PM by Dennis Toth »
Offline James Lee
Re: VECO 19 Venturi Insert into R/C carb mount.
« Reply #1 on: February 20, 2019, 08:11:52 PM »
Dennis
The answer is yes.   Actually, since this response is a bit late, the venturi is done...    ;D
Jim
