  • June 16, 2025, 12:42:31 PM
Author Topic: Hey Jim, prop shaft extension?  (Read 8666 times)
Offline Bob Reeves
    • Somethin'Xtra Inc.
« on: October 25, 2011, 06:30:36 AM »
I'm thinking about the feasibility of building an A4 for carrier with an OS 61 RR. The big problem is because it's a delta the engine would have to be located behind the canopy or it would need 15 ounces of tail weight. I'm thinking it will need a prop shaft extension but not sure how long till I figure out how big the thing will need to be.
Wonder how long I could go till I would need a carrier bearing and if I use a carrier bearing how will it get lubed. Would a sealed bearing hold up with a 61 turining 20 grand? Might be able to cut the length needed for the shaft extension with a custom spinner? So what ya think?
Online James Lee
Re: Hey Jim, prop shaft extension?
« Reply #1 on: October 25, 2011, 08:25:44 PM »
Bob
Try running a line from the muffler and let the exhaust oil give the bearing a bath.....
How about some drawings...?
Jim
« Reply #2 on: October 25, 2011, 08:41:03 PM »
Go ducted fan?
Dick Sarpoulis did a Hanriot Biche H 110 in Flying Models in 78 or some such.  It was a pusher; he put the engine in front with a boat propeller shaft back to a crank case in the rear; he fed the rear crank case with oil from the exhaust.
So it's been done, and been reported to work.
Offline rustler
« Reply #3 on: October 26, 2011, 03:22:47 PM »
I would think the prop drivers on the McCoy 60 are about as long as you would try as a pure cantilever extension, without a bearing. Similarly the extension on the K&B 7.5 DF engines. The revs those engines reach indicate it's an acceptable length if done to a high enough engineering standard. The longer the extension the more exagerated any slight misalignment becomes.
Ian Russell.
