  • June 16, 2025, 09:26:46 PM
Author Topic: Tank Bender  (Read 16597 times)
Online James Lee
Tank Bender
« on: July 30, 2008, 12:30:28 PM »
Now available is a tank bender in two configurations.  The 4" version will do tin of 4 1/8" width, and the 6" will do 6 1/8" width.
made from 1/4" by 1/2" steel with dowel pins to locate the bars.   The front piece is relieved at the corner to provide a radius.
The 4" bender is $15 and the 6" bender is $17.  Shipping will be $4
Offline Louis Rankin
Re: Tank Bender
« Reply #1 on: August 05, 2008, 07:47:34 PM »
I got mine in the mail last week.  It is a beauty.  Can't wait to give it a try.
Louis Rankin
Somerville Tennessee
AMA 10859
Offline Dick Byron
  • Vendor
Re: Tank Bender
« Reply #2 on: August 16, 2008, 09:45:05 AM »
Jim,
   I want the 4" bender. I will pay thru pay pal. How wide is the bar? Not length but width.
Dick Byron
Online James Lee
Re: Tank Bender
« Reply #3 on: August 17, 2008, 07:33:07 PM »
Dick
The tank bender pieces themselves are from 1/4" x 1/2" mild steel.    With 10-24 SHCS and 1/8" dowel alignment pins.....
Jim
Offline Dick Byron
  • Vendor
Re: Tank Bender
« Reply #4 on: August 18, 2008, 05:39:50 AM »
I got the e mail first. That is what I needed to know. I will send payment  by Pay Pal,
Thanks Jim.
Dick
Offline Dick Byron
  • Vendor
Re: Tank Bender
« Reply #5 on: August 20, 2008, 04:03:22 PM »
I got it today and just had to make one of the 1/2A tanks I need. Jim this is the slickest tools for making tanks. The best feature is being able to measure the size from the clamp to the 1000Th's of an inch assuring a square tank.
If you plan on building your own tanks, this is a must have.
Re: Tank Bender
« Reply #6 on: October 28, 2008, 06:44:12 PM »
If you build your own tanks, or think you might some day, you have to have one of these tools. I picked one up from Jim at Tulsa's contest and made my first tank with it today. Sure beats trying to line up two pieces of flat steel with two "C" clamps and trying to keep it all straight. Makes tank building a breeze except for those pesky end plates. I even used Jims tool to bend two of the sides on those. Try one! You will like it.
