  • June 16, 2025, 11:20:36 PM
Author Topic: Half A spinners  (Read 15096 times)
Offline James Lee
Half A spinners
« on: November 20, 2007, 06:30:04 PM »
Check out the latest product in stock.
One inch diameter spinners.
Spun aluminum cone with a turned backplate from 6061- T-6 alloy.  The nose piece has a 1/16" cross hole to tighten, with a 5-40 stud to fit into the supplied union nut.  These are fit together as a set.
No prop cut outs.  The assembly weighs just under a quarter of an ounce.
Price is $20 with $2 shipping
Re: Half A spinners
« Reply #1 on: November 22, 2007, 01:04:58 AM »
OUTTA SIGHT!!!!!!!!!!
That looks exactly like the old Frooms, but I know YOU wouldn't know anything about those. ;D
AWESOME!
Offline James Lee
Re: Half A spinners
« Reply #2 on: November 26, 2007, 01:28:30 PM »
The real answer is even more esoteric...!!   The cones are 1960's vintage Rev-Up....    The difference is the nose piece.  The one inch Froom had a truncated cone with a slot while the Rev-Up had the cross hole like the larger Froom and Veco spinners.   Todd found an original NIP Rev-Up Half A spinner one inch at Toledo last year....
Later
Jim
PS -  I will try to get a hardware set available to make these useable for the Norvel motors which use a 3mm x 0.5 screw...  just enough different to be a problem!!
Re: Half A spinners
« Reply #3 on: December 02, 2007, 11:02:34 AM »
Later
Jim
Thanks, Jim.  I didn't remember the differences in the nose cone unti you reminded me....
I really do need the Norvel set up, like yesterday! LOL!!!!!
Offline Dick Byron
  • Vendor
Re: Half A spinners
« Reply #4 on: March 18, 2008, 05:21:43 PM »
Jim I will need 2 for the AP Wasp .061. I am trying to find the thread size now. Found. It needs to have a m4 thread (4x0.7MM) Can you make them?
« Last Edit: March 19, 2008, 07:26:15 AM by Dick Byron »
Re: Half A spinners
« Reply #5 on: March 19, 2008, 08:47:42 AM »
I have a prototype, and it is awesome.  Great work, Jim!  y1
Offline Dick Byron
  • Vendor
Re: Half A spinners
« Reply #6 on: April 22, 2008, 08:11:27 AM »
Jim,
   I have 4 1/2 a spinners. 2 short nose and 2 needle nose. I was able to make the union nut out of stainless steel in a 4.7 mm thread and get 4.7 mm bolts to make them work. The AP Wasp needs 4.7 mm. I like the stronger crank shaft in the Wasp.
Offline James Lee
Re: Half A spinners
« Reply #7 on: April 28, 2008, 03:20:19 PM »
The one inch spinners are now available in 5 x 40, 3mm x 0.5 and 4mm x 0.7 threads
$20 plus $3 shipping
thanks  H^^
Jim Lee
Lee Machine Shop
Offline Dick Byron
  • Vendor
Re: Half A spinners
« Reply #8 on: May 01, 2008, 02:49:47 PM »
Jim,
    I just received the 2 I had you make. What can I say. Just superb. They fit the shaft of the AP Wasp exactly.
Thanks Jim
Dick
Offline James Lee
Re: Half A spinners
« Reply #9 on: May 02, 2008, 09:14:09 AM »
Dick
Glad to hear they fit correctly!!!   enjoy!!   H^^
Later
Jim
Offline John Rist
Re: Half A spinners
« Reply #10 on: October 26, 2008, 06:35:45 PM »
   Hi, James
I am building a twin 1/2 A profile DO335 that will have a pusher Cox Madilian .049 in the tail.  I need a 2" extension for the prop to extend through the tail assembly.  I don't need a lot of HP out of the back engine so I will put a easy start product jug and pistion on the back and a TD style jug and pistion on the frount. I have found a LH crank for the rear engine. Anyway 3 questions. 1)   Can this be done?  2) If yes what is the best way (through hole/long bolt or threated with studs aft and screw forward)? and 3) Can/Will you build one for me $? If you wish you can PM me. Who says 1/2 A is easy? mw~
Re: Half A spinners
« Reply #11 on: April 23, 2010, 12:35:02 PM »
I forgot to say that the Norvel set up of the 1" spinner is perfect!  Well, Jim, I wish I had know you about 30 years ago! LOL!!
Bill <><
