CLICK HERE--><--CLICK HERE
VECO 19 Venturi Insert into R/C carb mount.
Started by Dennis Toth, February 17, 2019, 04:16:57 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Dennis Toth
Jim,
Do you have or can you make up a venturi insert for a VECO 19 that had an R/C carb in it (See attached photo)? The stock venturi has a bore of  0.238" with a standard K&B NVA (0.158"), it has an outer diameter of 0.372", the distance from the bottom of the spraybar hole and the end of the venturi is 0.065", the distance from the top of the spraybar hole and the top of the flange is 0.104".
Please let me know.
Best,    Dennis Toth
James Lee
Dennis
The answer is yes.   Actually, since this response is a bit late, the venturi is done...    ;D
Jim
