The UHP kit has only a cut out, but most cut completely through. Neat thing is you can see the fuel level go down as you fly, assuming you use a see through tank. This is my second Imitation and if it flys like the first one, hooray for me. Also my second full fuse version, but this one from a kit. My first, I called the "Mimic", was broken at El Dorado when I did a dumb thing, then after repairs, the wings folded in a triangle while at Paducah. ALWAYS do a complete check on the entire wing after a break in the wing.
