  • July 12, 2025, 08:48:12 PM
Author Topic: WOULD THIS ENABLE FIELD CHARGING?  (Read 1807 times)
Online Dennis Adamisin
« on: July 01, 2013, 05:00:03 PM »
Lots of discussions on the topic of field charging:
* Taking a gas generator to use as a power source to charge batteries somehow seems wrong!
* Taking a separate deep discharge battery sounds…. heavy, and hard to do with anything short of a pick-up truck.
* Using the car battery is a mostly bad idea. HOWEVER, would a solar charger be a big enabler?
Did a little googling and found these solar car battery chargers.  Most are simply trickle chargers, but anti-up some folding money and the charge capacity goes up.  These solar chargers would be short of power to use directly as power sources BUT they would probably make it safe to use the car battery as the charging power source..  The solar charger would reduce the amount of power pulled out by the Lipo-charger and would replenish the car battery between Lipo-battery charges.  The solar panels are not inordinately expensive nor overly large and of course they work best when the sun shines the brightest!
http://www.autogeek.net/10-watt-solar-charger.html
http://www.batterymart.com/p-12v-15w-batteryminder-solar-battery-charger.htmldevice=c&network=g&matchtype=&gclid=COq5oMS7jrgCFVRo7AodgjkAbQ
Seems these and the smaller variations are popular with he boating & RV crwod.  SOme folks also use to keep the battery hot on a car/truck that is parked for extended period.  Anybody have any experience with these?  How much charging capacity is really needed to replenish & “save” the car battery under our likely charging cycles?
Offline Phil Krankowski
Re: WOULD THIS ENABLE FIELD CHARGING?
« Reply #1 on: July 01, 2013, 07:23:57 PM »
My imax b6 charger states 50W maximum output.
So if you are doing true solar charging then you are a few watts short.
However a 2000mah 3s is charged at 2A to about 11.1V (well, lets use 12V for simplicity) for 24W + the load of the charger.
Switch it around and a 18AH power sport battery is 18,000mah, or theoretically enough to recharge the previously stated 2000mah battery 9 times (excepting the load of the charger), so maybe the one panel would be enough to keep the battery from depleting too fast so you can keep flying.
I charge off my car and don't worry about it.
You can also look into a battery charging relay and put a second battery in the trunk charged off the engine, but isolated from the electrical system. (boating stuff)
Phil
Online Frank Imbriaco
« Reply #2 on: July 02, 2013, 07:42:32 AM »
Hi Dennis,
Last year I owned a roomy minivan and had a place for a deep discharge marine battery(Wal-Mart).
Thought that system was pretty good-especially since I didn't lift it in and out daily  and charged it while it was parked in my garage.
I replaced that vehicle with a 4dr Wrangler, so less room(duh !) BUT a convertible top ;D and 4-wheel drive  #^
Anyway, I've been using my vehicle battery for 2-3 charges on 4S and 5S and so far, all is well. Of course, different vehicles have different spec batteries.
Solar charging will no doubt get a lot of  attention  if a small, portable  panel can run my TP820CD.
Online Tim Wescott
« Reply #3 on: July 02, 2013, 11:05:37 AM »
This is an interesting thread.
Interesting because when I do the math I come up with the answer "don't use your car batteries to charge your LiPos -- you'll suck them dry".
Yet, when I fly RC electric I charge from my car all the time (and it's a little car with a little battery), and there's people here saying that's what they do, too, and I see other guys at my RC field with MUCH BIGGER PLANES (4500mAh, 7-cell packs) charging from their trucks.  So -- I'm confused, in a mathematically-oriented, engineering-ish sort of way.
If the "7 watts per ounce" rule is correct, then a 59 ounce plane uses about 150,000 Joules per flight.  If you assume near-perfect efficiency, that rounds to about 3.5 amp-hours (3500 mA-h) from your car battery per charge.
I did a quick check on car batteries; the first one that I found that would fit my 2000 Escort ZX2 had a 12 amp-hour capacity.  Which says that charging after just one flight would suck more than 1/3 the capacity of the battery.
Yet, when I fly electric RC, and per the testimony of the group, this can be done.  Maybe the one battery that I found was really wimpy, or had a very conservative amp-hour rating??
I think if you really wanted to be safe you should find a deep-discharge battery with 3.5 amp-hours per charge you intend to pump in.  Then charge it with solar or your car or whatever, but don't try to pull enough power directly from the sun to charge your LiPos, unless you're patient.
If you want to contribute to the group, poll your RC friends about what works, or toss some jumper cables into your car and go charge batteries at the field, then report back.
Offline Bob Hudak
« Reply #4 on: July 02, 2013, 01:31:02 PM »
Somewhere I read about a RC club that had a large 5'x10' solar panel that charged a couple deep cycle batteries and all the electric members had use of the solar storage facility. This was at a gated flying site. Also, this months Harbor Freight catalog has a 45 watt solar panel on sale for $149(reg. $249). 12 volt storage battery and 300 watt power inverter sold separately.It would be a good start at getting off the grid.
350838
« Reply #5 on: July 03, 2013, 08:54:44 PM »
I have not managed to kill the car battery charging at the field  I did have the minivan battery die suddenly at an early age - reading here about how easy it is to actually stress-out a car battery makes we wonder if thats that happened to me.
The econoboxt has no place to carry a deep discharge marine battery.  An all solar rig is too big to be easily portable.  The idea of using a solar make-up charger as a hedge against injuring the normal battery sounds like a viable compromise.
Bob: thanks for tip on the RC field set-up.
Offline Bob Hudak
« Reply #6 on: July 04, 2013, 06:53:45 AM »
Ahh!! I found the article.
              http://www.sky-knights.org/solar.htm
350838
Offline Dean Pappas
« Reply #7 on: July 07, 2013, 08:23:23 PM »
Hi Tim,
0.6 to 0.7 Watt-hours per ounce ... maybe?
  Dean
Dean Pappas
