  • June 23, 2025, 10:00:47 PM
Author Topic: Heavyweight!  (Read 943 times)
Offline David Shad
Heavyweight!
« on: November 05, 2010, 05:58:40 AM »
So...I have this stunter that was built for the PA .65...had a .75 in it too...but I don't have the
powertrain and Randy is out of stock for the forseeable future on them...and I am thinking...$600
for that or...an electric conversion that would probably cost less or if nothing else the same and I
would have several batteries for it.   I have read the current set-ups listed here but technology
changes all the time.   With the PA setup the plane weighs 70 ounces....What do you guys think?
What are the options?
Big Dave AMA 80235
Offline Robertc
Re: Heavyweight!
« Reply #1 on: November 05, 2010, 09:54:24 AM »
How many sq. in?  I'd venture a guess and say the same basic system as Paul Walker.  Look under List Your Set up.
Re: Heavyweight!
« Reply #2 on: November 05, 2010, 10:03:55 AM »
If you copy Pauls setup, you would want to use his first setup, not the current one. The current one is streamlined for a smaller lower drag airframe and wing.
Offline Dean Pappas
Re: Heavyweight!
« Reply #3 on: November 05, 2010, 11:31:16 AM »
Hi Dave,
Yup, how many squares? what does it weigh without the powerplant? Thick foils, fat foils, super-fat foils?
Landing gear: will the ship accept a 13" prop?
It does sound like a 5S, 3300 to 4000 mAH battery coupled with a motor that will probably weigh areond 8 ~ 10 oz with a Kv of somewhere between 720 and 850 will do.
I don't remember which Pletty or Hacker number to recommend right now, but I'll look them up at home. These two motors have the 3-rd bearing which should allow you to keep the firewall that is in the ship, if that's what you would do.
later,
Dean P.
Dean Pappas
Re: Heavyweight!
« Reply #4 on: November 05, 2010, 01:51:29 PM »
David:
Lots of big power choices out there, I have no quibbles with what others have already said here - just offering up one more variation.  We have been flying flying an 80 oz Strega with LOTS of power.  It uses a 6 cell pack to help keep the current draw lower and reduce the HEAT.  It can also use packs that are physically small.  Kenny Stevens recently converted an old PA-65 powered SV to the same power system and is very happy with it:
Arrowind 3526 Motor (Brodak BH-1841) http://www.brodak.com/shop_productdetail.php?ProductID=8844
Battery: depending on "dragginess" & final weight, 62x2200 mah or 6Sx2800 mah.  We have been flying the Strega on 2800's but believe we could use the 2200's, especially if it had a thinner wing or a little less weight.  THe 2200 pack saves 3 oz versus the 2800's: http://www.brodak.com/shop_productdetail.php?ProductID=8999 or  http://www.brodak.com/shop_productdetail.php?ProductID=8849
ESC: Castle Phoenix 45 or Ice 50 Lite, in "Set RPM" mode
Timer: Hubin FM-2SR (Brodak BH-1870)  http://www.brodak.com/shop_productdetail.php?ProductID=8860
Prop: APC 13x4.5EP (electric series pusher prop) turning about 9800-10,000 RPM
The biggest problem with CONVERTING an existing airframe is that it will likely gain a couple ounces - though compared to the old "gassie" with a full tank of fuel the weight differences get pretty small.  Building from scratch will let you make up any penalty...
Offline David Shad
Re: Heavyweight!
« Reply #5 on: November 05, 2010, 04:22:02 PM »
I should have thought to add the squares...756. 64 in span.
PW's setup lists a Plettenberg 30-12 with a 5s 4000 Battery.  Same size and weight.
Big Dave AMA 80235
