CLICK HERE--><--CLICK HERE
Why Fat Battery Wire?
Started by Howard Rush, February 17, 2025, 04:50:55 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Igor Burger
There are 2 things to consider. The first is that makers of ESCs expect that battery wire is part of transistors cooling. If you touch wires after flight, you will feel they are warm, much warmer than the current can heat them.
The second thing is that input current from battery can be chopped, especially in case of strong (high C rating) battery. So if I expect average current 20A chopped to 50/50 then it equals to average current (RMS) aproximately 30A. Safe thickness especially with thick insulation we use, will be 12AWG. If I want keep cooling function of the wire, it should be on "cold side" somewhere at 10AWG.
Howard mentioned my connectors:
https://www.rcsvet.sk/priemer-2mm/67692-21022-konektory-mp-jet-gold-25-pro-drat-25-mm2-2-pary-8595241390789.html
yes, they are expensive, but the are very well designed, having several contact poles and spring which is not part of the contact (so that proper material can be used for contact and also proper - different - for spring function) and also allowing easy installation of anti spark resistors. We found that they have lower resistance per unit of length than apropriate cable with diameter 2,5mm also after years of usage. And since they are designed for 2,5mm wire (thicker will not fit) I use 11AWG cable to battery and I keep orriginal (thicker - I think 10 AWG) cable to Spin ESC.
And that means that weaker batteries like lions having typically wider duty cycle (lower average RMS current at the same average current) because of high internal resistance and lower voltage duting run, will really work also with thinner cables, but still I will rather keep original thick cables on ESC.
Howard Rush
That is interesting.  I'll keep the fat wire on the ESC.  I imagine aluminum heat sinks on the ESC wire, being careful to stagger the fins to avoid shorts.
I estimate that cost difference between wire gauges is minimal for the manufacturer.
If I were making such a product I would opt for the larger wire gauge.
#1, it would protect me from warranty incidents based on underside wire.
#2, it would give the product a "heavy duty look" that would impress some customers.
One should keep wires short.  With short wires the wire gauge will make very little difference in weight.  I know a gram here and a gram there adds up.  But I personally thing there is better places to save weight. Reliability Just saying  -----  D>K
Mike Palko
Quote from: Howard Rush on February 21, 2025, 02:27:30 PM
That got me to wondering about all that copper in the nose.
You have a larger copper budget than most of us! If you've seen the nose of Howard's dog you would understand him wanting to save copper weight.
