Electric Stunt => Gettin all AMP'ed up! => Topic started by: linheart smith on March 05, 2012, 10:30:41 AM
Title: Who can guide me to Calculate # charges obtainable from car battery
Post by: linheart smith on March 05, 2012, 10:30:41 AM
Hi guys,
I am looking for the math to calculate the number of charges obtainable on a car battery given the cold cranking amps stated on new batteries.  They seem to range any wheres from 500 to 1000 CCA.  The smallest battery which could give me 5 to 10 charges would be nice because sometimes it is not convenient to walk back to the car where I fly.
Linheart
Title: Re: Who can guide me to Calculate # charges obtainable from car battery
Post by: Wynn Robins on March 05, 2012, 12:10:05 PM
Mike Palko did a nice article on this in control line world a couple or four years ago -I dont have the mags anymore - but from memory the CCA has nothing to do with capacity - it is the deliverable power at startup. capacity is waht you are looking for and a deep cycle - so it will provide the required amps for a long period of time.
Post by: John Rist on March 06, 2012, 01:19:02 PM
Looking at a $100 Sears RV (boat) battery it has an 80 Amp/hr rating.  If you are charging a 3S 3 amp/hr Lipo (3S 3000) - 80 divided by 3 = 26.  With losses etc it is reasonable to assume you should get at least 10 charges from this battery.  I'm guessing more.  4S would be less, 2S would be more.
 H^^
Post by: Mike Palko on March 06, 2012, 07:46:28 PM
Hi Linheart,
I got your email, but I thought it would be best to reply here for everyone’s benefit. This is taken directly from my article in the July 2009 issue of CLW.
To calculate the deep cycle capacity required take the lipo capacity used per flight and multiply it by the pack voltage to attain watt/hours (Wh).
16.8v x 2.5Ah = 42Wh
Multiply the watt hours by the number of charge cycles you require per flying session.
42Wh x 5charges cycles = 210Wh
The depth of discharge not to exceed for lead acid batteries is 50%. Since 210Wh is 100% we need twice this.
210Wh x 2 = 420Wh
The total deep cycle battery capacity required would then be 420Wh / 12v = 35Ah.
Cold cranking amps and reserve capacity are not directly related capacity. You can estimate the batteries capacity using them, but it is always best to start with a known capacity. I mention all three methods in CLW and can describe them here if people are truly interested.
As for real world experience I use a 75Ah battery and get about 6 to 7 charge cycles per session (5S and ~2,800mah used). With each passing season the lead acid battery degrades just like our lipo’s. I get about four seasons per deep cycle before I have to buy new. That’s if I maintain them which doesn’t always happen.
Post by: John Rist on March 07, 2012, 07:36:17 AM
Mike,
Does the don't go below 50% discharge apply to a deep cycle battery as well as car battery?  No doubt a car battery can cost a lot less.  Also is it true that one needs a good trickle charger to keep the battery healthy?
By the way looks like my good guess wasn't too far off.  Thanks for the good math on the subject.
 H^^   H^^   y1
Post by: Mike Palko on March 07, 2012, 11:18:32 AM
John,
Car batteries (starter batteries) should not be used for deep discharging applications. Anything more than one or two charges from a starter battery per flying session will shorten their life span. The internal design of a deep cycle battery is different than a starter battery. They are much more robust and are purpose built. The 50% rule is only for deep cycles.
A trickle charger should be used for both starter and deep cycle batteries when not in use for extended periods of time. Lipos should be stored partially charged, while lead acid should be stored fully charged.
Post by: Allan Perret on March 07, 2012, 11:40:03 AM
I bought what I thought was a "Deep Cycle" battery from Sam's.   Now after seeing this post and looking at the label I'm not so sure.  Its an Energizer E24MS, and the label says  Starting Marine.   CCA 500,  RC 95,  Marine Cranking Amps 650.
Post by: Mike Palko on March 07, 2012, 01:55:20 PM
Allan,
A quick google search turned up this link which gives and explanation of the three (starter, marine, deep cycle).
http://www.windsun.com/Batteries/Battery_FAQ.htm
Looks like a marine is a hybrid which I did not know myself. There is almost too much info in the link!
Post by: Allan Perret on March 07, 2012, 03:42:59 PM
Thanks for the link Mike.   I thought it gave a good explanation.   It said the Marine hybrid can actually be either a starting or a deep cycle.  So I still dont know what I have.  Doesnt really matter, will just be careful with it and never go more than 50% discharge.
