  • August 04, 2025, 08:46:30 AM
Author Topic: Which charger out of these two?  (Read 951 times)
Offline Russell Bond
  • Bandolero
« on: July 26, 2013, 04:11:16 AM »
Which charger out of these two do people think are the best (Most reliable and with least complaints?)
The iCharger 306B or the FMA Powerlab 6?
Or are they just as good as each other ???
Bandolero
Offline William DeMauro
Re: Which charger out of these two?
« Reply #1 on: July 26, 2013, 05:20:06 AM »
I own one of each.. As far as best bang for the buck , I think the 306 wins. If you want a customizable and even faster charger for multiple batteries and you don't mind some extra cost get the Powerlab 8. The feature I like most on the PL8 is that it can discharge almost twice as fast as the 306B. Both are great choices both will do what you need to do will and both are being used by the ECL community. I use both constantly and interchangeably. Both can do multiple batteries with paraboards or those multi battery charging cables.
AMA 98010
  • Bandolero
« Reply #2 on: July 26, 2013, 05:35:48 AM »
Hi William,
Thanks for the reply, at least I know they are as good as each other.
I'll check out the PL8 as well.
Bandolero
Offline jfv
« Reply #3 on: July 26, 2013, 06:24:02 AM »
I also vote for the Power Lab 8.  When I got mine it almost took time to charge out of the question and really helped with battery management as placing unused flite batteries back to storage is pretty fast.
Jim Vigani
Offline Dan Bregar
  • Field Marshall
« Reply #4 on: July 26, 2013, 06:36:43 AM »
After almost a year of use one of the buttons on my 306B became intermittent and had to send it back. Dale at EP Buddy replaced it with a new one under warranty. The FMA chargers may have a better frequency of repair record than the iChargers.
AMA 33676
« Reply #5 on: July 26, 2013, 08:22:19 AM »
Russel,
 I misread your first post I thought you were comparing pl8 with I-306B The PL6 has a similar discharge rate to the 306B and defiantly slower then the pl8. All are great chargers all will require a powerful high amp 24v power supply to get the max out of them. I still have some repurposed server supplies on hand if you eventually need one.
William
AMA 98010
