Electric Stunt => Gettin all AMP'ed up! => Topic started by: Andrew Borgogna on February 04, 2012, 04:50:02 PM
Title: When a crash site becomes a debris field, or what happens when a line snaps!
Post by: Andrew Borgogna on February 04, 2012, 04:50:02 PM
Well is was a beautiful morning is So.Cal. so I gathered up my Naughty Girl a new indoor plane and my PT-19 and headed for the field to meet up with some friends.  I decided to open up with a quick test of the new indoor plane.  Too breezy and made a rather hard landing in the grass.  All is well and I decided not to try again until an indoor site opens up.  So then I took the PT-19 out to the paved circle.  The flight started out very nice, I got my three laps in and just before I threw up my hand to signal the beginning of the pattern (I always practice how I will fly in a contest) I felt a sudden snap in the handle.  The PT-19 went strait in from about 8 feet at full power. :(  To say the plane was destroyed does not do the crash justice.  The motor, battery, plane all destroyed, the ESC showed damage but might be salvageable.  The timer looks OK but you talk about a debris field there were parts of airplane everywhere.  What a shame this plane was my park practice plane for Old Time Stunt.  The line snapped at the connector where it attached to the plane, it looked like it came apart inside the crimp.  These were fairly new lines and showed no sign of wear.  Oh well! HB~>
Andy
Title: Re: When a crash site becomes a debris field, or what happens when a line snaps!
Post by: Dennis Adamisin on February 04, 2012, 05:30:35 PM
That sucks - and you can quote me.   >:(   :'(   :X SH^
As I recall you had just got the PT dialed in too.  Ratz
Post by: John Rist on February 04, 2012, 06:05:51 PM
Andy
Don't like crimped lines. Too easy for the line to be damaged by over crimping.  Also can't see inside the crimp tube to inspect for damage.  I perfer wrapped lines.  Either Tom Morris ready made or I wrap my own using Tom Morris line wrapping jig.
http://www.clcentral.com/proddetail.asp?prod=TM%2D1500     :!
Post by: bob branch on February 04, 2012, 09:55:45 PM
now THAT is a bummer!
  :'( bob branch
Post by: Andrew Borgogna on February 05, 2012, 12:49:13 PM
You know Denny I really did finally have the PT-19 dialed in.  I would take it to the park and was having fun with it, oh well as I tell others if you can't deal with a crash you might want to take up bowling. ;D I am actually thinking about ordering another one and put a power package in it more suited to the plane.  As I said before Frankenstein was made up of leftovers and used to do an article in the club newsletter.  How did I know I would grow to like Franky?
I also believe I will not buy pre-made lines anymore and I will go to wire wound ends not crimped.  Anyway I am done wining. H^^
Andy
Post by: Larry Renger on February 06, 2012, 02:34:52 PM
Bummer!  The PT-19 was an execllent OT practice plane!
As I recall, you have an unused Flite Streak in your garage rafters.  Why not electrify that?
See you in a day or two.
Post by: William DeMauro on February 06, 2012, 05:30:41 PM
Andrew,
Sorry that you lost your plane. Were you using a castle controller? If so just send it in for "repair" and it will be replaced for a flat rate of around half price. I had one burn to a crisp in a crash, I put the remains(a few wires and and a crispy board) in an envelope and filled out the repair order http://www.castlecreations.com/support/repairs.html and about 2 weeks later i had a new one.
William
Post by: john e. holliday on February 07, 2012, 09:52:35 AM
Sorry to hear of your loss.   I have never liked crimped lines, even for combat.   I am sold on the the swagging method that Carl Shoupe put me onto.   Yes I have seen wrapped lines break even after a pull test and examination.    H^^
Post by: Andrew Borgogna on February 07, 2012, 09:56:07 AM
OK Doc, what's the swagging method?  I have no idea what that is refering to.  Believe me I want a good way to do this, a picture is worth a thousand words.
Andy
Post by: john e. holliday on February 07, 2012, 10:11:30 AM
Do a search for the following thread,   "Line Ends Cable".   The pics may be a little fuzzy, but they are there.   Carl makes/modifies long nose pliers for the swagging tool.   The furrels are copper.   Mine are 1/2 inch long.   The tube the line goes thru is copper or annealed brass tubing just big enough for the line/leadout.   I do it on leadouts also.    Easier to show in person.   I can make a set of lines in about a fourth of the time it takes to wrap a set. H^^
