  • July 11, 2025, 09:10:35 PM
Author Topic: What makes the APC 13 x 4.5EP thin blade so good?  (Read 2302 times)
Online Crist Rigotti
« on: October 04, 2012, 04:29:33 PM »
Guys,
This summer when checking out my Thundervolt, I used the APC 13 x 4.5EP thin blade cut down to 12".  While I felt it flew the plane well, in the hard corners there was a pronounced "woofing" of the blades.  Then I used a APC 13 x 4.5EP thick blade cut down to 12" and the "woofing" went away and it flew the airplane just as well.  It did use a little more mah because I had to run it about 500 rpm faster.  When I flew R/C helis, it the hard manouvers, the blades would "woof" which means they went slightly out of track.  My thinking is this is what is happening to the thin blade prop.  Going out of track can't be a very efficient way to run a prop.  So:
1) Those who fly the thin blade prop, does it "woof" on the hard corners?
2) If it does, why do you feel it's the prop to use?  Please be specific.
I'm just trying to understand where you guys are coming from in regards to the thin blade prop.
Thanks for your help.
Offline Russell Bond
  • Bandolero
Re: What makes the APC 13 x 4.5EP thin blade so good?
« Reply #1 on: October 04, 2012, 06:20:51 PM »
I have compared both the 13 x 4.5 and 5.5 thin pushers. (Not cut down).
The plane is 70oz ready to fly. (680 square ins).
With the 4.5 the RPM is 9600 for a 5.5/sec lap time
The 5.5 is 9200 RPM with a 5.45 secs/lap.
However, the 5.5 flies the plane slower through the maneuvers than the 4.5 prop does even though the lap times are faster on the 5.5 pitch prop.
The 5.5 pitch prop smooths the corners out slightly and tracks a little better but I feel the 4.5 pulls it through the pattern better.
I notice a bit of noise from the prop in the corners, but it's ok.
It just works!! ;D
Bandolero
Offline James Strickland
« Reply #2 on: October 06, 2012, 01:14:23 AM »
It's "better" or more useable power for our needs and situations that our models find themselves in (by all means, no doings of the pilot) LOL.  It's just like driving a manual trans. car/ truck and down shifting and driving in one gear lower, or something like that anyway.  Regards, James
Online Dennis Adamisin
« Reply #3 on: October 06, 2012, 07:04:03 AM »
Hi Crist
That is a tough question, made tougher by the observation that not everybody sees the exact same result.  I will speculate:
* First assumption is that we are comparing only governed systems but not comparing the governing systems themselves!
* The 13x4.5EP Thin Blade is lighter than the 13x5.5 thick blade and has less inertia. Thus it is possible that it responds more quickly to throttle "bumps" (up or down) and recovers RPM more quickly when doing square corners.
* The 13x4.5EP Thick Blade probably weighs near exactly the same as the 13x5.5EP Thick blade so weight & inertia effects should be pretty much the same.  However the 4.5 has to turn higher RPM than the 5.5; My opinion is that higher RPM is better when we are trying to climb or brake.
* So why do some set-ups exhibit differences one way or the other?  It could be influenced by the motor size and how loaded it is.  The 28xx motors on 4S turning a heavy prop and running at say 85% of its wattage capability will likely respond differently than a 35xx motor on 6S turning the same prop but only running at say 50% of its rated wattage capabiity.  The larger diameter motors SHOULD have more torque but also more inertia than the smaller motors.
*  The power/airplane also come into play.  I recall your prop tests on the Resolve 570; my take-away from that is that you could fly it with almost any 11"-13" prop and it would have been very successful.   By contrast my 80 oz Strega-beast test bed needs ALL the thrust & braking the prop has to give!
I do not have data to back this up, but a really intense look at ICE datalog might shed some light on some of these things.
« Reply #4 on: October 07, 2012, 01:25:17 AM »
BOY, was I offering a much more simple & WAY different point of view. That was a most excellent write up and explanation Dennis, thanks for that.
James
Offline Peter Germann
« Reply #5 on: October 07, 2012, 04:25:20 AM »
Dennis, attached is a number of logs recorded recently. Shown is RPM during five laps of level flight (left) and at time of the wingover manoeuvre (right) with Governor Gain set to min. respective max. values.
Airplane:  Max Bee  64 oz
Motor: AXI 2826/12
ESC: Castle Phoenix ICE lite 75A
Timer: Hubin FM-9
Timer signal: steady at 1.433 ms (for 9'624 RPM)
Battery: 5S2600 60C
Wheather:  light wind with low gain and calm with max. gain
Propeller: APC 13 x 5.5 EP
RPM set:  9'624
Lap (64ft x 0.015): 5.25"
ICE lite 75 A Governor Gain : Low (15) (Minimum) or Custom (50) (Maximum)
Head Speed Change Rate: Custom (20)
Motor Timing: Low (0) with min. gain and Custom (2) with max. gain
regards, Peter
« Last Edit: October 09, 2012, 03:54:05 AM by Peter Germann »
Peter Germann
« Reply #6 on: October 07, 2012, 07:07:02 AM »
That's great Peter.  Can you post it again with the THROTTLE curve?  The throttle input shows what kind of signal the ESC is sending to keep up with the target RPM setting - the dynamic responses to changes in prop load due to climbing, diving and square cornering.  The next step would be to use that comparison of prop "A" bersus prop "B".
« Reply #7 on: October 07, 2012, 07:54:52 AM »
Guys,
Excellent stuff!
Peter, I like your engineering approach to this.  Good hard data.   y1 y1 y1
« Reply #8 on: October 08, 2012, 06:55:29 AM »
The throttle signal was a flat and steady line at 1.433 ms coming from a Hubin FM-9 timer operating in New Phoenix High mode.
It's quite interesting to note that the only significant change resulting from switching from lowest to highest gain is the degree of RPM fluctuation in level flight (+/- 160 RPM vs  +/- 70 RPM) Response to load seems, within the limits of the inaccurate measuring method used, to be almost the same. I have added the high gain log to my earlier post meanwhile.
With the (APC 13 in EP) A and B props being very close in weight, I suspect the results of such a test, in tems of RPM drop/rise & response, being close,  too.
rgds, Peter
Peter Germann
Offline Dean Pappas
« Reply #9 on: October 19, 2012, 08:46:39 AM »
Hi Crist,
The woof in the corners could be from one of a couple of sources. The prop blades flexing and flapping (helicopter style) is the most likely one.
The next is motor mount flex which turns into a nutating or conical wobble driven by precession.
The two together can rip a motor mount out of the plane. I've seen it happen early on with 3000 Watt F3A setups!
take care,
   Dean p.
« Last Edit: October 19, 2012, 02:44:54 PM by Dean Pappas »
Dean Pappas
« Reply #10 on: October 19, 2012, 11:29:25 AM »
Hi Crist,
The two together can rip a motor mount out of the plane. I've seen it happen early on with 300 Watt F3A setups!
take care,
   Dean p.
Dean,
Thanks for your input.  I do believe that the woof comes from blade flex.  I'm trying to understand how so many perfer this prop with the blade flex over one that does not flex.  I do use a rear support bearing on my electrics and did not get a chance to fly this prop with it removed.  Some other day perhaps.
