  • June 16, 2025, 01:48:13 AM
Author Topic: Lith. Ion vers. Lith. Poly ?  (Read 675 times)
Offline Larry Wong
« on: September 08, 2011, 03:20:12 PM »
What is the difference ? I happen to notice that one of my charger was set on lithe. Ion and the other was on Poly I must have been charging them like that for a long time and not have any problem! Or did I !  8) ???
Larry
Re: Lith. Ion vers. Lith. Poly ?
« Reply #1 on: September 08, 2011, 04:38:53 PM »
AFAIK they're synonymous, although they both cover a range of details in the chemistries.
Offline William DeMauro
« Reply #2 on: September 08, 2011, 05:11:44 PM »
Lithium Ion settings will charge to 4.1V per cell. Lithum Poly charges to 4.2V per cell. Generally Lithium Ion cells have hard shells such as cell phone batteries or cylindrical cells like use in most laptops. Lipos like we use are soft shelled. Unless you don't have enough headroom charging to 4.1 volts per cell will not hurt them and my actually add some length of time to their lifespan.
AMA 98010
Offline Larry Wong
« Reply #3 on: September 08, 2011, 05:25:22 PM »
Thanks that is the answer I was looking for.  I use two cell-Pro 10's and till now I have never notice which one I use on each battery.I guess I can set the other to Poly-lipo and have both the same. #^
Larry
