  • July 24, 2025, 02:43:36 AM
Author Topic: What do you use....  (Read 1927 times)
Offline jim gilmore
What do you use....
« on: May 12, 2015, 02:04:07 PM »
For those that fly electric control line I am wondering what you use for a flight box ?
And what all do you bring to the field.
I assume that  one would bring propeller,batteries and flight line.
But not sure what else one should plan on needing.
I remember bringing a tube of ambroid glue among many other things when i flew gas models.
Pictures would be nice.
Offline Bob Hudak
Re: What do you use....
« Reply #1 on: May 12, 2015, 02:58:24 PM »
50 cal. Ammo box with handle,lines and batteries. I also bring my charger.
Bob
350838
Dwayne
« Reply #2 on: May 12, 2015, 04:05:44 PM »
All the stuff I'd normally carry, minus fuel and igniter plus chargers a small 500 watt 2 stroke generator and a 50 foot extension chord, those two strokes stink...lol  <=
« Reply #3 on: May 12, 2015, 04:27:51 PM »
Jim,
I use a Sear Craftsman tool bag for the tools. I use the ammo case for the batteries. I took a piece of aluminum flashing and bent it to form vertical separators that I slide the batteries into. I mark the battery ends one side with green tape the other with red. I put them in green side up when they are charged and red side after a flight. Has worked well for several years, you can get the ammo case at an Army/Navy store or online, under $10.
Best,  DennisT
Offline Phil Krankowski
« Reply #4 on: May 12, 2015, 05:28:01 PM »
Jim,
Best,  DennisT
Genius!
Phil
« Reply #5 on: May 12, 2015, 07:30:55 PM »
You can also mark your batteries with a sharpy 1,2,3,4 ect.
Offline John Cralley
« Reply #6 on: May 12, 2015, 07:41:37 PM »
I use a plastic caddy which has a handle in the center and two troughs (hard to describe).
I always wrap a rubber band around a battery when I charge it. I have to remove the rubber band to install the battery in a plane so I know that any battery without a rubber band has been used!!
John Cralley
AMA 52183
Central Illinois
Offline Curare
« Reply #7 on: May 13, 2015, 09:46:14 PM »
Ammo box for batteries, and a small bag for my reel and handle.
If I need anything more than that I go home!
Greg Kowalski
AUS 36694
