  • June 20, 2025, 04:02:25 AM
Author Topic: Info on Mounting  (Read 1492 times)
Offline David_Ruff
  • David Ruff
  • Retired Army
Info on Mounting
« on: August 12, 2014, 03:11:40 AM »
I am in the middle of converting an ARC Oriental to electric.  My battery and power system pretty much fill up the fuselage compartment.  I know I need to have good air circulation.
I would like to know some ideas about how to mount the battery.  It is huge; a 3300 three cell battery.  I am thinking of having it partially exposed to the airflow and not completely enclosing the battery and electrics.
I am new to this.
I am including two photos here.
I think if I can find a good way to mount the battery so that it is easily removed for charging, but very secure and sturdy, I am in good shape.
Ideas welcome.
I think I want to mount the battery on the starboard side of the fuselage.  It would be partially exposed in that case.
Power system is from Eric Rule of RSM.  It is a turnkey package and will be installed as you see it.
Just glad to be here
Offline John Rist
Re: Info on Mounting
« Reply #1 on: August 12, 2014, 01:58:06 PM »
All of my electric airplanes up to this point have been profiles with every thing hanging out in the wind.  However most of the pictures I have seen of built up bodies pretty much have flow through designs.  Most add an air scope on the bottom front and an air exit hole on the bottom just in front of the wing. also headers are open to allow air flow.  You need good airflow too keep everything happy.
 Look at the pictures in reply # 6 of: http://stunthanger.com/smf/index.php/topic,36031.0.html
As you can see every thing is open for air flow. I expect you are looking at the bottom.  The finished airplane probably has an air scope right in this area.  Just looking at your airplane pictures things look too boxed in.  Some how you need air flow over the motor, speed controller, and battery.  The KR timer protects for a lot of problems but if it stops the motor due to overheating the damage will have already been done.  Electrics, by nature,  just keep trying harder when things go wrong.  Smoke will soon follow.
Look at the pictures in List Your Set Up.   You will see many full bodied models. They all seem to have an air scope in front.
Offline David_Stack
« Reply #2 on: August 12, 2014, 02:39:28 PM »
Good Afternoon David;
  Give this a read...  http://stunthanger.com/smf/index.php/topic,14349.0.html
  It was another Forum member's 'conversion' of a Brodak T-Rex to electric power.
r/
