CLICK HERE--><--CLICK HERE
Arming Switch?
Started by DJohnson, February 08, 2026, 05:56:36 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
DJohnson
I have seen it written that arming plugs are required to be "legal".    I know they are a good safety mechanism, but I was not planning on putting one on my current build.  I usually open the hatch and disconnect the battery at the end of the flight.  Is this acceptable?
Bob Hudak
Yes, but be sure to show your Pittman how to unarm after your flight especially when in a contest. I'm sure you're aware if you dont disarm it's an automatic DQ.
350838
DJohnson
Quote from: Bob Hudak on February 08, 2026, 06:01:47 PM
Thank you sir!
Quote from: DJohnson on February 08, 2026, 05:56:36 PM
Sure, unplugging is legal.  Actually, unplugging is far BETTER.  Switches can fail dangerous if they get fused ON.  I bought a batch of XC60 switches and they didn't work at all.  I bought some arming plugs and they take so much force that the mounting adds too much weight.  Simply unplugging the battery is cheaper, lighter and safer.
Ken Culbertson
Arming "Switches" are not legal to my knowledge.  As Pauk says, they are prone to failure.  The switch that comes with the Spin ESC's is not a replacement for an arming "Plug" and the size necessary to carry the amperage we use would make them way too large.  A simple wall plug is only rated to 15 amps!  That switch we see on the Spin ESCs is a low voltage switch for the BEC and internal circuitry, not the battery.  I use that on my planes as a convenience and where it resides only reduced the amount of extra nose weight I have to carry.  A simple XT60 Arming Plug glued into the side of a plane adds very little weight and 100% safety.  There are times as well when the ESC and timer get confused and the only way to properly fix it is to remove all power and let the capacitors drain.  Without an arming plug you have quite a lot of time-consuming things to do while the clock is ticking.  It is also the fastest way to stop the motors in a crisis.  The timer reset has a delay.
DJohnson
All good stuff.  Appreciate the various thoughts.  I should have written more consistent.  I called it a switch in the title and a plug in the post.  I'm referring to the plug that you pull out or plug in.  I ordered a xt60 style plug and found it to be weak and clunky.  It takes considerable force to unplug and I could see the plastic housing coming apart or even ripping screws out at some point.  you also have the extra wires and internal connectors to dress in.  I'm mixed on the things and do not plan on installing it.  My battery connector will be easy to get to to disarm.  The master builders must hide them really good, because I rarely see them on those planes.
David
These plugs weight 1.03 ounces or 29.3 grams for the French.  But they require 4 pounds of force to unplug.  This worked OK on a fiberglass boat and a Skyray carrier plane where weight was not an issue.  The heavy duty mounting in the Skyray added another ounce, which didn't hinder it in that event.  You really only need to break one contact, but this rig pulls out two conductors.  A bullet connector in one wire would do the job, but still leave a challenge to streamline & beautify.
I bought some of these switches.  I don't recall where.  Either on line or at Toledo.  They weigh .825 ounces or 23.4 grams.
But out of a half dozen, none ever worked at all.  They were always "off".  They system worked OK with the switch removed from the circuit.  If a switch can fail safe it can also fail dangerous.  So I gave up on the idea of trusting switches.  In plugs we trust.
Ken Culbertson
Lots of folks seem to be looking for a ready made plug.  The only one that I know of is pictured above.  I have retrieved for several who use them and damn near tore the nose off getting them out.  They are massive overkill and heavy.  Just take an XT60 or any bullet type connector and make your own.  Mount them on a flat and Epoxy them in.  Sand the part that sticks out and don't worry about what it looks like so much.  It is out for appearance judging anyway.  This on is on my Endgame's rebuilt nose.
I agree with all that about excess force.  It's better to just have the holder hold the plane until the owner can pull the plug.
I use this device when flying alone with either mechanical or 2.4 launchers or with 2.4 or timer-controlled electrics.  A weight is plenty good enough to pull down elevator and terminate a getaway.  The weight in lieu of a stake allows me to move the center as required due the wind and whipping in to a landing.  Of course, at  contest where there are people around, just get one & avoid conflict.
