  • June 22, 2025, 11:47:38 PM
Author Topic: What amp Pro Spin Jetti controller do I need  (Read 2384 times)
Offline Tim Stagg
« on: June 30, 2021, 08:12:10 AM »
guys,
I am thinking about going with an active timer using the Foirotti timer and Igor 12-5 prop. do I need the 66amp pro spin or can I get away with the 44amp?
I plan on running 6 cells and either Cobra or bad ass motor for my full size stunt ship
Tim Stagg
Online John Rist
Re: What amp Pro Spin Jetti controller do I need
« Reply #1 on: June 30, 2021, 08:44:51 AM »
Looking at the prop chart for the Cobra 3525/18 a 12x6 APC pulls 27 amps on a 6cell LiPo (29.6V).  Based on that a 44 amp ESC should be OK. The max RPM for this setup is around 10K.  To get good RPM regulation you need to be running below this amount.  So your set RPMs will be in the 8.5K to 9K range.  So pick a prop and RPM needed for your ship. Then pick a motor that will support this setup and look at the prop data for max AMP draw.  D>K
Offline Fred Underwood
« Reply #2 on: June 30, 2021, 10:12:35 AM »
For "full size," 66 is best in my opinion.  Line length, ambient temperatures, wing loading, and others may affect amp draw and ESC heating.  I have used the Igor's 12 x 5N and run about 10,400 and with the 11 x 5 about 10,800.
Average amp draw will be about 20 ish, but peaks significantly higher.  Likely on amp values only, either will work, but most use 66.
Fred
352575
« Reply #3 on: June 30, 2021, 12:12:29 PM »
guys,
I recently posed this question for the same timer and was advised that the Spin44Pro was just fine for the Foirotti regulating a BadAss 3515-710 so that is what I bought for my first replacement ship after the fire.  I have it installed and bench tested and it appears fine.  Another local expert flier uses the Spin44 on the same motor using Igor's timer.  I have dropped back to 5 cell batteries.  I don't find the extra weight justifies the rather minor performance difference.
Offline Tim Stagg
« Reply #4 on: June 30, 2021, 01:40:02 PM »
thanks guys,
I plan to go back to 5 as soon as my current thunderpower 6 cells degrade...however I just bought them this year, broke them in have maybe 3 flight each so I am hoping that will be a couple of years
Fred and Ken, thanks for your setup overviews
Tim Stagg
« Reply #5 on: June 30, 2021, 04:49:29 PM »
As noted, the Spin 44 will run it fine and with the same program.  I'm not sure that there is a flying performance difference.  The 44 should be fine with adequate cooling.  I have seen them used on profiles, and full fuse around 600 squares.  I assumed that Igor would have used the 44 and saved weight if it seemed as good in the long run.  Maybe he will comment.  Again, just an opinion :-)
Fred
352575
« Reply #6 on: June 30, 2021, 07:11:46 PM »
Fred
352575
Offline Tim Stagg
« Reply #7 on: July 01, 2021, 07:31:27 AM »
Thanks Fred, based on Igors post looks like the 66 is the one
Tim Stagg
Offline Rogerio Fiorotti
    • Control Line by Fiorotti
« Reply #8 on: July 01, 2021, 05:33:59 PM »
Hi guys,
I know the ESC Spin is very good but Castle Talon 60 has good ones, talk to David Chang about the test with Talon 60.
Rogerio Fiorotti
Offline Crist Rigotti
« Reply #9 on: July 01, 2021, 06:50:11 PM »
Hi guys,
Rogerio Fiorotti
Where can I find this test?
Offline Tim Stagg
« Reply #10 on: July 02, 2021, 07:17:22 AM »
Rogerio,
I have multiple castle edge 50's but was told their reaction tie is not fast enough to provide the results needed for your active timer. Is the Talons reaction times faster than the edge.
forgive me  if I am not using the correct terminology.
Thanks, I would rather stay in the castle family if they provide the same performance.
Tim
Tim Stagg
« Reply #11 on: July 02, 2021, 03:36:37 PM »
Contact David Chang on Messenger.
Rogerio.
« Reply #12 on: July 02, 2021, 03:41:52 PM »
Rogerio,
Tim
Tim,
Edge 50 has delay due to datalogger, disabling it improves performance.
Talon does not have the datalogger and was developed for use in helicopters being faster in rpm change.
Rogerio.
Offline Tim Stagg
« Reply #13 on: July 06, 2021, 07:04:22 AM »
Thank you Rogerio
Tim Stagg
