  • June 16, 2025, 04:01:31 PM
Author Topic: Axial Free Play  (Read 1143 times)
Axial Free Play
« on: December 22, 2019, 08:13:29 AM »
blank
« Last Edit: August 23, 2021, 09:24:10 PM by Motorman »
Re: Axial Free Play
« Reply #1 on: December 22, 2019, 06:49:26 PM »
Not to be snippy, you want the minimum free play that doesn't slow the motor down when you fly maneuvers.  A ball bearing shaft should have a few thousandths more clearance the the clearance in the bearing.
With the bearings taking up all the load the clearance between the case and the prop driver doesn't really matter, as long as the prop driver can't drag on the case.
Online Crist Rigotti
Re: Axial Free Play
« Reply #2 on: December 22, 2019, 06:55:34 PM »
Have you asked the motor manufacturer?
Offline Tony Vitiello
Re: Axial Free Play
« Reply #3 on: April 19, 2020, 05:51:41 PM »
Did we ever come up with a turnkey 1/2a morning expensive electric setup?  My kids are flying my old 1/2a cox engines but they are finicky even with some new parts on them. If I could build a few electrics I could get the kids from their school flying these. Even though my kids are average 11-14 year olds and spend too much time on electronics, they do enjoy control line, more than RC actually.
I bet we could get kids in model airplanes with these ideas. Right now is a great time because you can fly these almost anywhere while we are pretty well locked down.
Re: Axial Free Play
« Reply #4 on: April 19, 2020, 06:17:01 PM »
Apparently not.
Re: Axial Free Play
« Reply #5 on: April 19, 2020, 07:09:39 PM »
I’ll try and figure this out with a readily available motor, esc  and battery from somewhere. The key is you need to know parents of young kids. I have young kids so no problem but other need to talk to your grown kids if you have them and have them recruit kids from their schools, scouts, sports teams.
Re: Axial Free Play
« Reply #6 on: April 20, 2020, 07:55:22 AM »
Does Phil's answer deal with expansion of the motor when it's running etc?  It's always best to consult the manufacturer.  No offense to Phil.
Re: Axial Free Play
« Reply #7 on: April 21, 2020, 08:40:49 PM »
Great.  Thanks for sharing.
