  • July 15, 2025, 03:53:27 PM
Author Topic: Vector 40 upgrade  (Read 4467 times)
Offline Warren Leadbeatter
  • AUS-14782
    • My Home Page
Vector 40 upgrade
« on: February 16, 2010, 12:32:35 AM »
Ok guys, next project.
I have a Brodak Vector 40 that I built from a kit in 2006.  It has a OSLA40 engine in it and I have never really been ultra happy with this motor.  At first I had problems with run-away, so I tamed it down, but then it seemed under powered and rather inconsistent. The model currently weighs 49oz wet. It flies well and is still in good gondition but has always been let down by inconsistent motor runs, hence it spends a lot of time not being flown.
I am now planning to UPGRADE it to electric power.
I know I will use a Castle ICE LITE 50 and Hubin FM2-R timer. At the moment I am considering which motor I will use. My options are:
Turnigy 3542D-1000kV Eq AXI 2820
Turnigy 3548-900kV Eq AXI 2826
Arrowind 2820-07 (aka Brodak EPS40)
Arrowind 2826-06
Scorpion SII 3020 920kV
The battery will be whatever is required, but I would like some feedback on which motor you all think would be the best for this setup. I'm leaning towards the Turnigy 3542 because I like the way the prop drive is done and cheap at around $20US but I am concerned about it being under powered.
With the Arrowind and the Scorpion, obviously price is a concern and I'm not really a fan of the way their props attach.
Warren
Warren Leadbeatter
Port Stephens, Australia
AUS-14782
Offline Archie Adamisin
Re: Vector 40 upgrade
« Reply #1 on: February 16, 2010, 06:30:13 AM »
Warren,
The Turnigy SK 35-42-1000Kv is a great motor.  My Uncle Dennis uses it in his Mythbuster and it works perfectly.  I would recomend this motor with the ICE 50, 11 x 5.5 prop or a trimmed down 13 x 4.5 "P" prop to 11 to 11.5 in.  Use 4S 2350 to 2650 Li-Poly.  Fly on 63' lines and you will have a winner.  Try to keep the weight in the mid 40 ounce range.  You will not be dissapointed with this set-up.  It will man handle the Vector.  Fly it around 5.0-5.1 sec/lap.  Vector 40 seems to be happy there.
Uncle Dennis is converting his Vector to use the EPS 40 system.  Should see the same results.
Archie Adamisin
Muncie, Indiana
Archie Adamisin
Burlington, KY
Offline John Paris
« Reply #2 on: February 16, 2010, 09:52:44 AM »
Archie,
Are you recommending the ICE 50 or the ICE 50 lite on this one?
John Paris
269
Alan Hahn
« Reply #3 on: February 16, 2010, 12:08:10 PM »
Archie,
John,
Not Archie, but I think I would go for the Lite. The Vector 40 is already pretty narrow in the front, even for the Lite (at least compared to my Phoenix 45). I don't think I could get the normal Lite with its large heatsink into the fuse (I don't have the normal one so could be wrong there).
I think the only reason to go for a "normal" Ice would be if you want to run 7s Lipo pack and above. The Lite is limited to 6s, and I think its firmware won't even let you go above that (but I'm not absolutely sure about that).
« Reply #4 on: February 16, 2010, 12:21:02 PM »
Ice 50 Lite is all that is required.  As Alan has pointed out before, the Heat Sink is for the BEC that we really don't use enough power on to make any difference.  I bought the Ice 50's with Heat sink as I am using 6S on my CLPA bird and the weight wasn't really an issue to me.  I could have used the lite without issues on it as well.
Archie Adamisin
Muncie, Indiana
Archie Adamisin
Burlington, KY
  • AUS-14782
    • My Home Page
« Reply #5 on: February 16, 2010, 02:07:36 PM »
Warren,
Is this motor the same as the Turnigy C3542-1000Kv?  ie The Gold and Chrome one?
Cheers
Warren Leadbeatter
AUS-14782
Offline Mike Anderson
« Reply #6 on: February 16, 2010, 02:58:36 PM »
HobbyKing has 2 different 'versions' of some of their motors -
The gold/chrome ones are the "C" versions.
The Black/chrome ones are the "SK" versions - larger shafts (in some models - not the 3542 however), improved bearings and possibly improved magnets.  I have flown a C3548 and an SK3548 in the same plane and would not have known the difference from the flying.  The SK version is slightly heavier and in the 3548 model, very slightly longer.  For some reason, in the 3548 size, their site shows the SK as being colored gold/chrome also, but we've never gotten anything but black ones, and in our club there are at least a dozen of them flying.
(There is a rumor on the HobbyKing forum that "SK" stands for "Scorpion Killer" - a couple of years ago there was a rather heated debate on their forums concerning the quality of Scorpion motors vs. the Turnigy line.  Led to the banning of the US Scorpion dealer from their forums.  Having flown both, I can say that while the Turnigy is good for the price, Scorpion has nothing to worry about.).
Mike@   AMA 10086
Central Iowa
Online Dennis Adamisin
« Reply #7 on: February 16, 2010, 03:04:51 PM »
Cheers
Hi Warren
I'm using the SK version which is black & chrome.  However I really do no think there would be any problems with the gold version.  BTW, check out the "List your set-ups" link for a couple Vectors, I think Alan used a Scorpion 3020 (same size) with a 12x6 prop.
BTW I am planning on replacing my SK 35-42 with a Brodak-Arrowind 2820.  No real NEED to, but I feel compelled.  My always supportive nephew already said he'd take the SK off my hands so I wouldn't have to worry about it cluttering up the shop - what a guy...
« Reply #8 on: February 16, 2010, 03:11:59 PM »
Warren,
For the difference in cost, I prefer the SK series as I feel they are better built.  I have a 35-42-1100 Gold Series and a 35-42-1000 SK. I have run both.  I will be using the gold series in my new Classic bird and the SK in another classic bird that will follow.  Both motors run very closely and from the handle and even with a data logger, I doubt you will see much of a difference.
The Scorpion motors I have seen are very nicely built and run very good.  Crist, Alan, and Will have been very successful with them.  I prefer Turnigy as I now own stock in them. I have the following:
(1) 28-36-1200Kv (Red & Blue series)
(1) 35-42-1100Kv ("C" series Gold & Chrome)
(1) 35-42-1000Kv SK
(2) 35-42-1250Kv SK
(1) 35-48-1100Kv SK
(1) 42-40-1050Kv (Purple motor)
(1) 42-50-650Kv SK
The (2) 35-42-1250's are for R/C EF-1 Pylon Racers, but the rest are dedicated ECL motors.  The Vector 40 will work well with either 35-42 motor.
Archie Adamisin
Muncie, Indiana
Archie Adamisin
Burlington, KY
Alan Hahn
« Reply #9 on: February 16, 2010, 06:25:06 PM »
Well I'll vote for my Scorpion!
I was looking into the AXI2826-12 (kV=760) and was surprised to find that my Scorpion 3020-780 (kV=780) that I am using on my Vector had just about the same winding resistance, so overall should perform just about the same (theoretically --efficiency wise) as the AXi, but I at a lower weight (5.81 oz vs 6.3 oz).
But this is just a recommendation. We aren't really pushing motors of this size, so I believe almost all will work well.
  • AUS-14782
    • My Home Page
« Reply #10 on: February 16, 2010, 06:28:28 PM »
Thanks guys for the excellent feedback.  I think since one is only $17 and the other is $20 I might be able to afford to buy one of each and try them both!  I might convert another model as well!  ;D
Cheers
« Last Edit: February 17, 2010, 01:53:50 AM by Warren Leadbeatter »
Warren Leadbeatter
AUS-14782
Offline Igor Burger
« Reply #11 on: February 17, 2010, 01:49:45 AM »
I am surprised, I thought the scorpion has lower resistance ... I think axi has 40mohm, while sc has 30 if I remember numbers well. Also no load current is lower at sc, I think by 0.1A so it should have better efficiency, but you are right, real values are exactly the same, on 6sA123 they have both input power 335W on stand with APC 12x4 at 9100rpm, while AXI 2826/10 (kv=920, ri=28, i0=2.2) needs 370W and AXI 2826/13 needs 330W (kv=680, ri=42, i0=1.4)
however the same axi 2826/10 needs only 340W instead of 370W if used on 4 lipos :-)
 ... I am still somehow confused what parameters to look for to find best efficiency under load at 80-90% PWM
Alan Hahn
« Reply #12 on: February 17, 2010, 07:43:09 AM »
It is also a little tricky relying on motor winding resistance, because in actuality, you need to also consider the ESC. But I was just a "little" surprised that they were so close. If I look at the values on "DriveCalc", where someone (not me) has entered some actual measurements of these two motors under load, the "effective" resistance is a lot closer to each other.
But I suppose the motors are similar because the Scorpion 3020 has a wider diameter stator which must offset at least some of the extra length of the AXI 2826. That's my guess anyway!
  • AUS-14782
    • My Home Page
« Reply #13 on: March 25, 2010, 05:22:19 PM »
Ok here it is all ready to go!  Prop 11x5.5 E, Weight it a little on the fat side at 50 oz.  A bit of a tight squeeze to fit everything in, but it balances nice... should be good in the air I reckon.
Well I hope it does... I'm flying it at www.gscmar.com tomorrow!
« Last Edit: March 26, 2010, 02:39:23 AM by Warren Leadbeatter »
Warren Leadbeatter
AUS-14782
  • AUS-14782
    • My Home Page
« Reply #14 on: March 27, 2010, 12:36:07 AM »
Flew the Vector today. Had 3 excellent flights. Awesome. 9500 rpm is what I guessed and it's right on the money, using about 1800mAH of a 2650mAH battery.  I'm going to add a little nose weight though as it's just a tiny bit twitchy.  More flights tomorrow...
Warren Leadbeatter
AUS-14782
« Reply #15 on: March 27, 2010, 04:45:14 AM »
Warren:
CONGRATS again!  Let's see, by my count that is 3 successful electrics in about 3 months - keep this up and folks are going to think you are SERIOUS about ECL!
Had this one previously flown as IC or was this ECL from the start?
  • AUS-14782
    • My Home Page
« Reply #16 on: March 27, 2010, 05:54:20 AM »
Dennis,
I think it's pretty much a given that I am a convert for F2B.  I want all my F2B models to have electric right now!  As for Classic Stunt, well they will stay as glow engines and my Sig Twistang with the Saito 30, it will never change.
I'm going to focus on flying the Vector now for our State Champs in June. The Vector had a OS LA40 which I was never really happy with.  Seemed to run fine here by the water at sea level, but as soon as I took it somewhere inland it would misbehave.
Bruce and I were flying together today and will be again tomorrow... we are the F2B electric trail blazers of Oz lol
I was watching Bruce's model today flying with a APC 13 x4.5 Pusher now... it flies so slow yet powerful, he's doing something like 5.8 second laps now, he had to extend the flight time to finish the pattern. I was standing about 6 feet away from the circle and could feel the prop wash as he turned near me.  So much thrust!
It was so impressive, even the radio control guys were coming over and asking us questions about our electric setup.
Cheers
Warren Leadbeatter
AUS-14782
Offline TDM
« Reply #17 on: March 27, 2010, 08:21:36 AM »
Warren if the plane corners well and it does not hunt do not add the nose weight. Instead bringthe spacing on your handle closer together to suit your flying stile. If yo move the CG forward several things will happen like more weight needds More Amps to drive, the corner will suffer and you need more deflection on the flaps which will need more acceleration it all compounds in the wrong direction.
Dorin
« Reply #18 on: March 27, 2010, 06:56:27 PM »
Warren
Well, I am pretty sure that your motor will run pretty much the same no matter where you fly it - so THAT problem should be solved.  ALso, I re-read the thread and saw where you said you flew it at 49 oz with the LA40.  If your conversion is only 1 oz more than I'd say you did pretty good.
The LA40 is a pretty heavy engine, so I'll bet your CG is aft of where it used to be.  Still Dorin's advice might save you any more extra weight.
My Vector revision got pushed aside by other projects, but I plan on cutting windows into the rear fuse sides, replacing the heavy fin, and sanding some cubes off the stab.  Collectively that should all help, in its first iteration this Vector was a wee bit tail heavy for me.
  • AUS-14782
    • My Home Page
« Reply #19 on: March 27, 2010, 11:08:53 PM »
Hi Guys
I added 1/2 oz in the nose and have moved the leadouts back slightly today an had 3 really good flights with it.  It flew better than yesterday and is doing 5.3 sec laps.  I'll keep playing with it and I'm sure I will get it really good.  In the past with the IC engine I spent all my time trying to get the motor running right. Now I can focus on getting it to fly right as well as improving my flying ability.
Bruce's model is flying really nice too.  Here's a pic showing where we were flying.
Edit: tonight I removed the weights and replaced them with a battery safety Y cable thingo.  One thing I did notice tonight also, that I used more power today. Yesterday I used 1800mah, today I used 2100maH the only things that changed was the 1/2 oz of nose weight and I increased the Governor gain.  What did it? The 1/2oz weight gain, the governor gain change or both?
Cheers
« Last Edit: March 28, 2010, 03:20:42 AM by Warren Leadbeatter »
Warren Leadbeatter
AUS-14782
« Reply #20 on: March 28, 2010, 04:42:29 AM »
Hi Guys
Cheers
I doubt the 1/2 oz had any effect, more likely the goverrnor gain AND less wind.  No wind conditions tend to turn up the power usage.  Where are you on the gov gain setting?  Did it make a difference flying?
  • AUS-14782
    • My Home Page
« Reply #21 on: March 28, 2010, 05:25:20 AM »
Hi Dennis
There was virtually no wind in the morning on both days.  The governor gain was set at Medium yesterday then I thought I would try it at High today. Didn't notice any difference other than the current increase.
I did notice yesterday on my third flight when the wind did come up that it used less power than the previous no wind flights so was aware of that.
Will do some more playing.  I'm yet to try the magical 12x6 EP on it.
Cheers
Warren Leadbeatter
AUS-14782
Offline Dean Pappas
« Reply #22 on: March 28, 2010, 09:40:57 PM »
I'm with Dennis 100%!
More ponies where you need it leads to more battery consumption.
Even hitting harder corners leads to more consumption.
Dean P.
Dean Pappas
  • AUS-14782
    • My Home Page
« Reply #23 on: April 02, 2010, 04:14:32 PM »
I think I might have figured it out.  I forgot that I changed the Brake setting from Soft to Hard.
Warren Leadbeatter
AUS-14782
