  • June 19, 2025, 04:09:49 AM
Author Topic: Flying Electric in the Wet  (Read 1583 times)
Offline David Hoover
« on: December 24, 2014, 06:59:28 AM »
I don't mean pouring rain but sometimes at a contest you need put up a flight in light rain.  Also, it's not uncommon to get to the flying field early in the morning and there's fog or mist hanging around for the first flight or so.  I've found that IC power is not happy in those conditions and I was wondering if anyone has any experience with electrics in similar conditions.
Best, Hoovie
Offline Crist Rigotti
Re: Flying Electric in the Wet
« Reply #1 on: December 24, 2014, 09:24:44 AM »
No problems what-so-ever.  Another advantage of electric.
« Reply #2 on: December 24, 2014, 11:07:49 AM »
That's odd -- I've flown in those conditions quite a lot, and hadn't noticed that my IC engine was particularly unhappy.
If you've got that early morning fog that only comes about because the air is absolutely still, then you're going to have serious issues with hitting your own wake -- that's not a power plant issue, though, that's an aerodynamic issue.
If the cause of the performance degradation is the airframe needing more power in still air (which has been noted over and over by the electric guys), then as long as you have sufficient  power you should be fine.
Dwayne
« Reply #3 on: December 25, 2014, 04:20:51 PM »
If you're talking about getting it wet, I use electric (as do many others) on my R/C float plane with no issues.
