  • June 18, 2025, 08:27:50 PM
Author Topic: Plettenberg Orbit Bearings  (Read 4497 times)
« on: July 07, 2016, 04:28:38 PM »
Where can one get bearings for a Plettenberg 20-16?  What sizes are they?
Thanks.
Re: Plettenberg Orbit Bearings
« Reply #1 on: July 07, 2016, 05:01:43 PM »
What did Boca say when you called them?
They're almost certainly standard sizes, and almost certainly metric.  If you don't want to get them from Boca, measure them, convert the measurements to metric if your calipers aren't enlightened enough, then buy those sizes from McMaster.
« Reply #2 on: July 07, 2016, 06:55:35 PM »
Boca's Web site does not include Plettenberg.  I reckon I could call them.  The motor in question is my spare.  It works, but is a little noisy.  I don't want to disassemble it until I have replacement bearings in hand.
Offline Mike Haverly
« Reply #3 on: July 07, 2016, 08:45:17 PM »
You're welcome to take my spare Plettenberg to NATS if you'd like.  Let me know.
« Reply #4 on: July 07, 2016, 08:52:02 PM »
It's a deal! Thanks.
« Reply #5 on: July 07, 2016, 09:42:45 PM »
We don't need no stinking Plettenburgs.
Offline Jeff Traxler
  • T-Bone
« Reply #6 on: July 08, 2016, 07:46:58 AM »
Binklemas bearings on the WWW.They have bearings for everything
Offline Paul Walker
« Reply #7 on: July 08, 2016, 07:55:43 PM »
Oh yes you do!
Offline Paul Walker
« Reply #8 on: July 08, 2016, 07:58:36 PM »
Thanks.
Jeez, what kind of motor is that. The original bearings only lasted about 5 years.  Compare that to my Scorpion motors that lasted maybe 100 flights. That doesn't translate into too many weeks.
Offline Dane Martin
  • heli pilot BHOR
« Reply #9 on: July 08, 2016, 10:48:44 PM »
Howard, I don't know about plettenberg motors as they relate to CL, but this company is a distributer.
http://www.f3aunlimited.com
My friend Kevin is a Nats competitor for RC pattern,  and highly recommend's their service. You will need to call or email them though.
Offline Igor Burger
« Reply #10 on: July 09, 2016, 12:48:56 AM »
I tried high quality japan bearings for high load, did not help ... I tried also ceramic without success ... and when I saw balls from them, then I understood, they are so small that they act as a sanding material, not bearing :-P
Offline Lauri Malila
« Reply #11 on: July 09, 2016, 04:38:11 AM »
Of course I have no own experience with this, but it sounds like a lubrication problem rather than bearing type/quality. What do you use as lubricant and does it stay there? L
Offline Igor Burger
« Reply #12 on: July 09, 2016, 04:57:48 AM »
It is not good idea to dissolve thick lubricant in bearing - everything what goes in, will also go out. So short nswer for me is "nothing" :- ))
« Reply #13 on: July 09, 2016, 02:08:09 PM »
I sent them a note, but it looks like they only have the 30 series.  Thanks.
« Reply #14 on: July 09, 2016, 02:12:14 PM »
Whatever it came with and probably not, respectively.
I couldn't find them.
  • T-Bone
« Reply #15 on: July 10, 2016, 08:03:19 AM »
Howard,Try the Binkelman Corp Toledo.They evidently sell more than the bearings I buy from them.......I'd post a link but the dummy operating my computer can't figure out how LL~ LL~ LL~
« Reply #16 on: July 10, 2016, 11:56:24 AM »
Thanks.  I found them.  I don't know the sizes, though.
Offline Darkstar1
« Reply #17 on: July 11, 2016, 10:35:34 AM »
Howard,
I've bought bearings from Boca they were close but not exact, especially the large one. I would contact Plettenberg
directly and get the bearings from them. If you're not in a hurry U can get them in 2 weeks. as far as lubricant goes
I would use it on the small ones. little to none on the big one.
Later,
Evolve or get left behind!
Offline Kim Doherty
« Reply #18 on: July 11, 2016, 10:37:39 AM »
Why don't you contact the distributor?
http://www.icare-rc.com/plettenberg.htm
Kim
