  • July 08, 2025, 06:44:36 PM
Author Topic: Unplugging the Battery  (Read 1373 times)
Offline Jeff Traxler
  • T-Bone
« on: July 15, 2011, 12:22:52 PM »
Hi All,
   Just a quick question about the ESC/battery connecting plug.I have arthritis and I have difficulty unplugging my battery after the flight and removing it from the charger sometimes.I know the connections must be tight to prevent arcing but I have tried Dean's,XT-60,EC-3 and they are all a pain in the hind end to disconnect.Any ideas,tools or suggestions(Besides going back to glow) out there????Thanx,Jeff
Re: Unplugging the Battery
« Reply #1 on: July 15, 2011, 12:27:52 PM »
You may try Anderson Power poles, they are easier to get plugged and unplugged, though they are a bit larger and more bulky,,
http://www.powerwerx.com/anderson-powerpoles/powerpole-sets/
Offline Crist Rigotti
« Reply #2 on: July 15, 2011, 12:28:49 PM »
I've seen somewhere that somebody drilled small holes in each side of their Deans connectors, then used a snap ring pliers to pull them apart.
Here's a link:
http://www.rcgroups.com/forums/showthread.php?t=437499&highlight=deans+snap+ring
Offline WhittleN
« Reply #3 on: July 15, 2011, 12:47:33 PM »
Jeff
$4.99 I have a set and use them just for that - not to mention taking snap rings of electric motors.
http://www.harborfreight.com/hand-tools/pliers/snap-ring-pliers-with-interchangeable-heads-3316.html
Norm
« Reply #4 on: July 15, 2011, 03:53:31 PM »
Or loop string through the holes and pull on the loops.  I like the snap ring plier idea, though.
  • T-Bone
« Reply #5 on: July 16, 2011, 03:22:38 PM »
Thanx for the tips fellas.Nescessity is the mother of invention and my dad is a mechanical engineer.I have him working on an idea and maybe the perfect tool still needs created.Until that happens Harbor Freight is a couple miles from my house and the snap ring pliers will have to do.Much better than tearing up an aircraft just trying to unplug the battery.Tips,suggestions and ideas for this yet to be created tool are gladly accepted.Jeff
« Reply #6 on: July 21, 2011, 06:42:16 PM »
You really don't want to use metal pliers around a battery capable of hundreds of short-circuit amperes!
Better to file some notches in both connector halves, to make gripping with your (insulated) fingers easier.
F.C.
Online Larry Wong
« Reply #7 on: July 21, 2011, 07:27:23 PM »
Hi: Guys I have been using a dab of Dielectric  grease  and working it in and out a couple times, have work for me with no problems.  n~ <=
Larry
« Reply #8 on: July 21, 2011, 08:10:27 PM »
I believe Jeff said he has arthritis.  Probably has trouble even gripping the connectors.
« Reply #9 on: July 22, 2011, 08:46:50 AM »
In my days of RC playing I remember an individual with the connectors.  He had a string tied around each one so he could pull them apart.   H^^
Offline Dean Pappas
« Reply #10 on: July 22, 2011, 09:09:58 AM »
That sounds safer than the circlip pliers!
Dean
Dean Pappas
« Reply #11 on: July 22, 2011, 11:09:36 AM »
Dean
Sure does.
