Electric Stunt => Gettin all AMP'ed up! => Topic started by: paul winter on November 01, 2012, 12:44:17 PM
hi all
electric is great
now its time to build my p38
but i need a wiring diagram to run one battery two esc'c and one timer
HELP please
paul
Paul,
Not to hard. Here it is in it's simplest form. This assumes your ESC's are like most and have a built in BEC (battery eliminator circuit). It can get more complicated depending on the level of sophistication of your equipment
Just be careful not to get battery leads too long. Might want to consider two battries.
Is this a scale or a stunt project. If scale you might want to consider a 2.4 ghz setup for throttle controll. Lots of comments on the scale board.
John,
I don't wont to risk hijacking this thread, as there is a lot of good information on battery lead length elsewhere on this forum and the internet. I'd like to pose a question to you - wouldn't it be OK to add a little battery lead length, e.g. a short wye, to a twin as you have already doubled the amount of capacitors in the circuit (2 ESC's)?
How about contacting the one and only one Bobby Hunt.
