  • July 07, 2025, 12:33:51 AM
Author Topic: Turnigy SK 35-48 900 k/v? Is this OK?  (Read 4327 times)
Offline CharlesF
« on: March 26, 2009, 02:41:29 PM »
Hi
I'm keen to start buying the bits to go electric C/L. I've seen this motor on eBay Turnigy SK 35-48 900 k/v
Would it do with a 3s pack for a 35 sized plane? Or is the k/v too low for 3s? They also have an 1100 k/v motor
Also, are all Castle Creations controllers capable of constant speed "governor" operation? The RC guys seem to prefer the "constant power" type of controller
Charles
Alan Hahn
Re: Turnigy SK 35-48 900 k/v? Is this OK?
« Reply #1 on: March 26, 2009, 03:19:21 PM »
I am not familiar with that motor, but I think a 900kV motor is better suited to a 4s battery setup. On some of my motor tests with an 880kV motor running at 8000 rpm, the 3s pack ends up needing full throttle from the ESC just to maintain the 8000 rpm in level flight power levels, leaving nothing extra for maneuvers. A 3s pack needs a kV in the 1000-1200 range, depending somewhat on what your target rpm is--determined by prop load. The detail to remember is voltage available will be less than the nominal lipo voltage (just battery internal resistance) plus the drop in voltage as the battery discharges. Another detail is that at least for me, maneuvering power is about 30% higher than cruise power (as I recall, you can look at the peaks in the data plot I gave in response to your energy question). So you need to keep that sort of reserve available, even at the end of the flight when the battery voltage has dropped.
Here is a plot of a "typical" discharge. The horizontal axis is how much charge has been pulled out, the vertical axis is the battery terminal voltage, and you have different curves for different current outputs. Recall a 10C discharge implies that you have pulled out all the charge in 6 minutes.
I am not sure about constant power ---in our case we need more power for maneuvering. So the constant rpm mode makes sense--as the load goes up, the power increases to keep rpm constant. Not that it wouldn't be nice to get an extra boost in rpm when you needed it, but that requires something smart figuring out when to give you the boost (I call it Fox 35 technology!  LL~).  All the Castle Creation Phoenix ESC's have the governor mode. Their cheaper ESC, the Thunderbird does NOT.
Offline CharlesF
« Reply #2 on: March 26, 2009, 04:20:16 PM »
Thanks again Alan,
I've been reading through various posts this evening - all very interesting. What I meant by constant power is really like a series-wound DC motor (as used in railway locos!) Constant speed is defintely what we want
There's an 1100 k/v motor, so I think I'll go for that, for a bit of headroom
Charles
« Reply #3 on: March 26, 2009, 04:47:44 PM »
Charles,
how many watts is the turnigy capable of producing? for sport flying and light manuevers something around 110 to 120 watts per pound of airplane would be ok,,, but for flyign the pattern the standard is to be able to generate more along the lines of 150 watts per pound so for an airplane that weighs 48 oz ready to fly ( three pounds) you want to be able to generate in the neighborhood of 450 watts
Offline Mike Anderson
« Reply #4 on: March 26, 2009, 06:17:30 PM »
Hi
Charles
It will do very well on 4 cells - it will fly a Twister size plane through the pattern on 3 cells, but you don't have much left for wind.  Turns a 12-6 at about 7500 and 30 amps on 3 cells, 8800 (PLUS) at ??? amps  on 4 cells.
The -1100 will turn a 12-6 at over 9000 RPM on 3 cells, drawing about 40 Amps.  It is plenty of guts to fly lots of different planes.  Also does pretty well with an 11-5.5 on smaller planes at 30-35 amps.
The "C" models of these (The "SK" is the 'improved' version) are nearly as good.  The -1100 "SK" was about 300 RPM better than the -1100 "C", on the same prop and battery.
The only thing you have to watch out for is that on more than one occasion, we've gotten motors that were mis-labelled (We've begun to call it "CQC" where the QC stands for "Quality Control").  My new Twister is flying with a "C3548-1100" that only turns 7500 RPM at 30 amps  - coincidentally the exact same performance as my buddy's "SK3548-900" on three cells.  Not worried, though, as a new "SK3548-1100" has already shipped and should be here soon.  It's always exciting to see if the performance matches the sticker ...
Here are some pictures of the plane (and the mis-labelled motor):
« Last Edit: March 26, 2009, 06:57:52 PM by Mike Anderson »
Mike@   AMA 10086
Central Iowa
Offline CharlesF
« Reply #5 on: March 27, 2009, 03:14:53 AM »
Thanks!
I ordered one of the 1100 k/v motors last night. Now I am mulling over a controller. They do a 40A one that has governor mode (with a little programming card)
Charles
« Reply #6 on: March 27, 2009, 06:12:29 AM »
The Governor mode on the Turnigy is reported to not work as expected - I think Dennis Adamisin and Will Hubin can fill in details for you.  In addition it is also reported to run rather hot.  If you feel you MUST have Governor, then the Castle Phoenix, Jeti Spin and the German ESC's are the way to go.  There are 'cheap' ESC's that advertise governor mode ("Heli" version) that I would stay away from.  They do not have a Brake, and the Governor mode is not what we consider "Governor" mode.  For sport flying, if you can get by without governor mode, the BP/Suppo 45 amp has a big heatsink and has many programmable features (but no card available - must be 'stick programmed') but works well.  The Turnigy 60 amp maybe wouldn't run as hot as the 40 amp.  Again, the running "Hot" is hearsay, we have one in the club here, but it has only one flight on it (yesterday) and the motor is not the -1100, it's the -900, and the owner is an electric Newbie, so I don't know for sure if it is or isn't problematic.  You could always get one of the Hobbycity "Supersimple ESC's" (the 50 amp seems to be the same ESC as the BP/Suppo 45 Amp) for $10 or so to use while you research a better ESC.
Mike@   AMA 10086
Central Iowa
Offline William DeMauro
« Reply #7 on: March 27, 2009, 06:25:54 AM »
If you want a Phoenix Todds Models seems to have about the best prices on them. The 35 amp is $62.99 and 45 amp is $79.99 http://www.toddsmodels.com/Castle_Creations_ESC_s/39.htm. If you prefer something else Hobby City has the TURNIGY Plush 40amp Speed Controller for $34.95 http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=2165&Product_Name=TURNIGY_Plush_40amp_Speed_Controller and it's $6.95 for the programming card if you need it. I have a Turnigy but haven't used it yet. I am sure others can comment on its performance. See above which got in while I was typing this one.
AMA 98010
« Reply #8 on: March 27, 2009, 08:02:19 AM »
My two cents worth, if you go "off the reservation" with your ESC theres likely not much help for programing at least in the control line world. If you go with the Castle Creations Pheonix, there is quite a few people here that use it.
as for Govenor, If you plan on doing PA with your plane, I would suggest that there is no effective way to get around using govenor, if you are sport flying, then perhaps the govenor would not be as important. The govenor will maintain rpm while you manuever, very important for PA
« Reply #9 on: March 27, 2009, 08:24:35 AM »
I agree with Mark and only use the Pheonex speed controllers on the planes I fly more seriously. If I use the Turnigy at all it will probably go on a ARF Flight Streak that I will convert for my 12 year old son who is still learning his stunts. In any case I am home from work for at least a week or 2 with a broken finger and 3 stitches so maybe I will do some ground testing on the Turnigy.
AMA 98010
Offline CharlesF
« Reply #10 on: March 27, 2009, 10:04:58 AM »
Hi
Yes, I think the CC Phoenix is my best bet. Once I get a bit more experience I can try the "more strange" ones. I also like that I can programme the CC from my laptop
Charles
« Reply #11 on: March 27, 2009, 11:08:57 AM »
CharlesF
As Mike indicated I have experience with the Turnigies - I have 5 Turnigy 40A ESC's - but they are now all in a box.   :'(
The problem is that they do NOT govern to maintain a set rpm.  Thus your motor speed deteriorates as the battery wears down.  Will Hubin did some bench tests that show it MIGHT be feasible to use the Turnigy IF you also have a "throttle up" or compensating timer that increases throttle setting over the course of the flight.  There are a couple such timers out there (and I am not familiar with all of them),  Will has the FM-1A timer which actually ramps up the throttle over time to try to maintain a near constant RPM.  I have some FM-1A timers and I am going to try them with a Turnigy ESC in a OTS sport model this spring.  I have no illusions that it will perform like a Phoenix, but I am hoping this will let me recoup some of my investment in Turnigy ESC's!
My expectation is that the FM-1A timer with the throttle-up functionality will make the Turnigy ESC into a workable piece for a sport model - without the "throttle up" the Turnigy it is virually unusable for CL.  They should work OK for RC though.
Another problem both Will and I have noted with the Turnigy is that they seem to be a little unstable with heat - but that has been harder to pin down.  My brother the 'puter geek is fitting all my Turnigies with CPU heat sinks to nullify any possible heat issue.
On the plus side: The Will Hubin Timer with Turnigy is very easy to set-up.  Will's timer has easy to set controls - when you use it with the Turnigy controller all you need is a small Phillips screwdriver & a tach to set your target RPM - no PC required.  The Turnigy programming card is easy to use, and the ESC WILL let you set "governor" simultaneously with an effective prop brake.  One more plus - The The Turnigy "Sentry"(?) series has a connector that you can plug into your LiPo balancing plug.  The ESC actually monitors battery balance.  That seems like an idea other ESC's might some day copy.
In flight the Turnigy seemed to govern during manuvers.  I THINK (but I did not get a lot of experience with this) that the Turnigy governor might deal with short duration load changes to maintain more constant RPM.  However, because you do not program a target RPM into it it has no target to try to maintain as the battery wears down.
Depending on your intentions for your ECL bird the Turnigy with compensating timer MIGHT be good enough.  For a sport model - probably OK.  I'm cautiously optimistic that it will work in a OTS model I'm working on.  However, for ECL-CLPA there is no substitute for the Phoenix.
« Reply #12 on: March 27, 2009, 03:20:24 PM »
I ran 2 ground tests with my Turnigy today on my P40 and 1 in the air test as the weather cooperated for about an hour.(No I didn't fly the new one yet). On both ground tests I ran my usual downsized 8x6 that I use for on ground testing to set up my RPM's. This speed control even with a light load could not hold the RPM at the 9000 that I tried to set it for. I was using the FM-1a timer that Dennis A spoke about. On the second test I dialed a little throttle up into it and was able to hold it reasonably steady. I then put my 12x6 APC on it and went to do an in the air test. I didn't tach it but suspect that my RPM was not at 9000 as preset with the other prop.(This doesn't happen with the Phoenix). The flight was OK but a little light on the lines. The RPM did seem to hold close to where I set it. Like Dennis I would only use this speed control for sport flying and with a boost setting on the speed control. This will work out fine if I ever get around to converting the ARF Flight Streak for my son. If not maybe I can use it in an electric powered rc glider someday.
AMA 98010
Alan Hahn
« Reply #13 on: March 27, 2009, 04:06:44 PM »
William,
have you ever given us the details on the P40 setup? I'm kludging a recycled glow one together, and may have it in a flyable state by next week. Curious to get a starting point on power settings--prop and rpm I guess!
« Reply #14 on: March 27, 2009, 06:08:44 PM »
Alan,
I hate to hijack a thread and probably posted these details before.(lost in the crash probably). This is the setup that I had in the P40 that worked. Phoenix 45 in Set RPM at 9000 RPM. Will Hubin timer customized for me for set RPM mode.(See SV11 Thread). The timer and speed control were tested here for the sole purpose of ending up in the SV 11. APC12x6 then electric Prop, Scorpion 3020-14  http://www.neoplanes.com/radio-control/scorpion-3020-14-brushless-motor-outrunner.html. Line length 61' eyelet to eyelet. Laptimes around 5.1-5.2 seconds. Battery 4S 4000mah. The setup that I used today was thrown together in about an hour with stuff I had but wasn't currently using. Hope this helps as a starting point.
William
AMA 98010
Alan Hahn
« Reply #15 on: March 27, 2009, 06:23:23 PM »
That's more or less the hardware where I'm starting, so the rpm target is useful.
Offline Ralph Wenzel (d)
« Reply #16 on: March 29, 2009, 11:15:32 PM »
If it'll help with finding data on this engine, remember that "Turnigy" was originally "Hextronic".
Ralph Wenzel
AMA 495785 League City, TX
Offline Archie Adamisin
« Reply #17 on: March 30, 2009, 07:38:38 AM »
I have been flying a new Turnigy SK 35-48-1100 on 4s in a converted Q-500 for 3 weeks.  The motor is a beast.  The 800 watt rating is accurate.  I have tested it @ a sustained 675 watts for 2.5 minutes and it doesn't even get warm.  I am flying it on 4S and have used from a 9 x 7.5 to 10 x 8 and haven't over loaded yet.  (Of course it is at full throttle at all times @ flying over 100 mph during this test.)  I am going to now test it on larger stunt props because I plan to use it in a 625-650 square in CLPA around 50-54 ozs.  At max power, it would give 237 watts/lb at that weight.  This motor is no slouch.  I agree that on 3S, it will need as much prop as you can give it to make power.  This motor is like the polular AXI 26-26 series which many have used successfully in larger airframes on 4S.
My 2 cents
Archie Adamisin
Muncie, Indiana
Archie Adamisin
Burlington, KY
« Reply #18 on: March 30, 2009, 10:16:14 AM »
We had a new SK3548-1100 out yesterday, mounted on the ARF PT-19.  With 3s1p-4400 Zippy, 12-6 APCe it was turning 8700 RPM at 38 amps (ground) .. and pulls like a tractor and barely warms up.  Another new one, the SK3548-900 on four cells is also in the initial test stages but I don't have any amp or rpm data on it yet.
Mike@   AMA 10086
Central Iowa
