Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 16, 2025, 12:05:54 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Electric Stunt
Gettin all AMP'ed up!
(Moderator:
Dean Pappas
APC 12 x 6 Pusher prop,I'am sold.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: APC 12 x 6 Pusher prop,I'am sold. (Read 759 times)
Paul Allen
2014 Supporters
Trade Count:
0
Captain
on:
March 03, 2010, 09:23:45 PM »
Just had 4 flights with the pusher prop on the Scorpion 890kv motor
in the E Cardinal,works great,very good in the wind,running 8450 rpm
and added 1 ft in line length to 61 ft end to end,0.015",lap time 5.3 sec.
Logged
Dennis Adamisin
2019 supporter
Trade Count:
0
Admiral
Re: APC 12 x 6 Pusher prop,I'am sold.
Reply #1 on:
March 04, 2010, 04:28:18 PM »
...and the magic-prop claims another convert..!
Logged
Dennis Toth
2020 supporter
Trade Count:
0
Admiral
Reply #2 on:
March 04, 2010, 07:24:11 PM »
Paul,
The next thing to try is an 11x6 3 blade Pushers Master Air Screw or one of Dennis A's 13x4.5 3 blade Pusher APC's cut to 12 and run at around 9200rpm. I have been flying the 3 blades and like the way they pull in the corner. If you use the MAS as received the pitch is about 1.5" less then the marked pitch, you can either repitch with a heat gun or bump up the rpm until the lap time comes in. They are a little more work to balance (just start sanding the face of the heaviest blade first then move to the second heavy, work back and forth between those two and it will come in). On my ship the 3 blade is very smooth and quiet, also seems to create less wake in dead air. Good luck.
DennisT
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Electric Stunt
(Moderator:
Dean Pappas
