  • July 15, 2025, 01:26:52 PM
Author Topic: Turnigy Aerodrive SK3 - 4240-740Kg Do you know?  (Read 2094 times)
Offline Guilherme Souza
« on: June 05, 2017, 10:05:44 AM »
I bought this motor sometime ago , same weight of Cobra 3520 and EFlitec32 .
My plane is a little heavy , almost 2000 gr . I was using cobra or Hyperion motor .
What do you think?
Enviado de meu ASUS_Z00AD usando Tapatalk
Re: Turnigy Aerodrive SK3 - 4240-740Kg Do you know?
« Reply #1 on: June 09, 2017, 08:37:52 PM »
Dear All
My test was not so good .
I use 5S 2700 mha , 13x6 prop
Fiorotti active timer  .
the first 2 minutes was ok but after the motor loose power
I did 4 flight with different batterys with all the same result
After each flight I put the finger in the motor , if I leave my finger I could burn me .
the temperature was very high .
When I used Cobra or Eflite the temperature was little hot .
I think If I use a smaller prop and higher rpm the motor would work better .
But I can do more tests now , I have contest in JATAI  state of Goias in Brazil .
A little far from home  800 miles , but one of best contest in country .
Thank you
Guil
« Reply #2 on: July 06, 2017, 09:55:36 PM »
Dear all
I did today  a good flight with this motor
I īm using 12x6 apc prop  and Fiorotti timer
I did 2 flights of 5 minutes  , no problem with the motor
My plane is a Legacy converted to eletric , my old Legacy
I think this motor is a good choice and cheap
thank you
Guil
« Reply #3 on: July 07, 2017, 08:48:44 AM »
Guil,  wish you good luck or performance with your set up.  I sit here now thinking 800 miles for a contest, but it hit me that not that many years ago most contests for me was over 200 miles and several were in the 550+ mile range with our nationals being a 1400 mile trip one way.  With Marcus no longer with us I hope you can give us a good report on the contest and the fun you guys have.  When I seen the photos of the guy/gals and the feast after flying all day made me wish I was better off financially so I could come to you country and join you guys.  But, any way have fun and do good at the contest.
