How about some temperature readings? We are running Plettenberg 25/12 motor, Schulze 18.46 and 18.61 ESC with Thunderpower 5s 3900 Mah batteries.
Average temperatures after 6 minute flight:
Motor: 120 degrees Fahrenheit
ESC: 115 degrees Fahrenheit
Battery: 110 degrees Fahrenheit
We are flying in the HOT Florida sun (92-95 ambient air temp) and measurement of the temperature is accomplished with a laser temperature gauge directly on the components immediately after flight.
Does anyone have recommended safe temperature ranges?
Jim Smith
Hi Jim,
Considering your high OATs, your system temps are very good. They are all within safe limits.
In answer to your question, the rough rule of thumb for all three items is:
IF YOU CAN TOUCH IT FOR SEVERAL SECONDS WITHOUT PAIN THEN YOU ARE OK.
(I suggest using your left hand if your right handed, please don't ask how I came to this conclusion
BTW: Normal human touch without pain is roughly somewhere between 115 to 125
The temp numbers are:
MOTOR
The Ideal world for our motors would be somewhere colder than 100 degrees below ZERO.
....... For our purposes up to 130 F is still OK without doing any serious damage to the magnets or epoxy. When you pass between 150 to 180 you are shortening the life of the motor and lowering it's performance permanently. When you pass 180 to 220 there is a high risk of epoxy failure and having one or more magnets cause some serious damage inside your motor. It should come as no surprise that there is a wide variance between the very cheap motors and the higher quality motors like Plentenberg, Hacker, AXI, etc. when it comes to temp. tolerance.
ESC
These magical wonderful devices should be kept under 120 F. Best is as cool as possible. They will tolerate higher temps, but they are subject to problems/failure if they overheat. Over 140 to 180 and trouble is sure to follow.
BATTERY
The opposite from the above is true here. They like to be "warm". Their ideal world is somewhere between 90 F to 115 F. If they are below about 50 to 55 F you should try to warm them up. (search this site for methods guys use to do this). You will NOT have full power available if your batteries are below 50 to 55 F, and it goes down fast from here.
This means that, for many, they may have to make sure the airflow to the battery is decreased during cold WX flying to keep the battery above this 50 to 55F temp. At the higher end, our batteries do not like high temps either. Above 130 to 140F and you begin to shorten their life span. Above 150 to 160 F and they become very unhappy.
Easy gauge: If it hurts to touch it, it is too hot ...... If your tongue sticks to it when you lick it, then it is too cold.
MEASURING TEMPS
Scotts suggestion is excellent. In addition to mail-order, these inexpensive temp gauges can be purchased at most LHS that carry RC Cars. They are usually more accurate than the hand held gauges. (The hand held gauges are OK for our use, the other is just a little better.) If you are really interested in monitoring and controlling your systems temps, then you may want to use the outstanding "Eagle Tree" onboard system. Many on this site have used it. It records ALL temps, RPM, Amps, A/C speed, etc. and plays them back on your computer and or plots a graph for your entire flight.
The temp #s I have given above are from reading many mfg. sites, and talking with my ERC flying friends who are aerospace engineers, and from personal experiences and experiments. ..... Of course, your milage may vary.
