  • August 05, 2025, 01:23:27 AM
Author Topic: too much info  (Read 2433 times)
Offline paul winter
too much info
« on: December 22, 2012, 01:04:31 PM »
hi all
one of my friends who wants to get into electric control line flying
Is blown away buy the amount of technical info people are throwing at him ,,
,do we need it all or are we frightening people away who are not technically minded from IT overload  ???
Re: too much info
« Reply #1 on: December 22, 2012, 01:43:11 PM »
There should be an idiot's guide.
No, wait -- there is an idiot's guide.  Several of them, in fact.  The best one, if you just want to buy your way to success, is the packages offered by Brodak's.
Go to the Brodak's site, click on their link to their electric stuff, and then look for the EPS-40, EPS-50, and EPS-60.  Look at the kits that they're recommended for, and get the one that roughly matches the size of your plane.  If in doubt, get a bigger one and a collection of propellers to fool around with -- the only down side you'll create for yourself is weight.
The biggest problem of all is that there are so many choices.  The second biggest is that there's a lot of folks that don't know a lot about electronics or basic physics giving out advice (and really, you don't need to know much of either).  The third biggest is the whole market niche thing -- we don't command a big enough market share for some big company to make products specifically for us, so getting things to work is all about adapting ESCs and whatnot to our use.  The fourth biggest problem is that the market is still new, so the choices of timers is constantly changing (and not well advertized, because of the third biggest problem).
Edit:
Sorry, the thing to look at on Brodak's site is their "Arrowind Power Systems" chart:http://brodak.com/media/pdf/Arrowind_Power_Systems.pdf.  You still have to match from whatever you're building to the similar Brodak kit, but everything is selected by an expert to play well together
« Last Edit: December 22, 2012, 02:05:30 PM by Tim Wescott »
Re: too much info
« Reply #2 on: December 22, 2012, 07:00:09 PM »
hi all
Hi Paul
I think part of the problem is that folks are EXPECTING it to be really complicated - and since their first ECL is on the Vertical part of the learning curve. - it looks more intimidating than it is.  I guess its just like when you built your first IC model - how did you KNOW what size engine? What size prop?  Round square or wedge tank - in metal or plastic?
To borrow from Tim's post I'm the "idiot" (thanks, Tim) who put the chart together on the Brodak site, it of course features Arrowind products that Brodak stocks, however it can be used generically to select Brand "X" motrs or Brand "Y" Esc's or batteries.  I keep coming back to the best way to select the equivalent power system is to start at the PROP DIAMETER then match the motor, ESC & battery to that.  One weakness of the chart is that it targets sport and stunt type applications - if you want to build a 100 mph combat model that chart will not lead you there.
I have also been working one-on-one with folks who order from Brodak and want help.  Recently one gentleman started off with all the "fearful" questions, but he bought a set of hardware, set it up on the bench, ran it and concluded it wasn't so difficult afterall.  He is now in the process of doing what looks to be a real nice install in a Oriental - I predict success.
ECL info is still scarce, even among controliners ECL is a minority.  Realisitically the best sources are on-line.  I try to encourage everyone I work with to join Stunt Hanger.  Of course SSW now has an electric forum so there will be good info posted and available there too.
Re: too much info
« Reply #3 on: December 22, 2012, 09:14:30 PM »
I think another part of the problem is that some people just panic as soon as watts or amps or volts enter into the conversation.  If you can't grasp the relationship among those, then it gets hard to understand how to pick a green battery if you happen to have a part number for a red one.
Offline Andrew Borgogna
  • Andy
Re: too much info
« Reply #4 on: December 23, 2012, 06:54:20 AM »
Well I do believe there is a learning curve to electric and it does require some amount of study.  We all tend to forget the amount of time we spent learning to make IC work and, sorry to say there isn't a great deal of IC knowledge to leverage off of.  I do like the "turn key" offerings that Brodak and RSM offer but they are not the complete answer to the problem.  I know this because of all the emails I get from people who have purchased a turn key product and then get into trouble.  The latest got the wrong kind of battery charger and ruined all his batteries and then couldn't figure out why his system didn't work right.
I spent 40 years in computers as a tech and engineer and I still managed to burn up my first system because I didn't know what I was doing.  Let's not forget that watts and amps and volts not to mention ESC, timer, governor and all the settings we make are "Greek" to the beginner.  So I say lets offer all the help we can and encourage people to join us in the electric world.
Andy
Andrew B. Borgogna
Offline paul winter
Re: too much info
« Reply #5 on: December 23, 2012, 07:55:49 AM »
when we all started I/c we latched onto someone who knew and was guided by them ,the problem is now people are dissecting electric too much as the world is all computers now
the days of simplicity has gone
 The list that Chris lists at the top of the forum is so helpful ,it certainly helped me and many others ...
paul
James_Mynes
Re: too much info
« Reply #6 on: July 28, 2013, 01:30:39 PM »
Speaking as a new to electric control line flyer, I don't find the packages offered by Brodak or RSM to be all that informative. Yes, you can "buy your way to success", but it doesn't help me to understand certain terms I see bandied about on this forum. Terms like 'outrunner' and 'inrunner' come to mind immediately, but there are others.
I've seen the explanations of battery capacity, number of cells, charge rates, and all the other happy stuff that 'help' you choose the right battery. Motors, on the other hand, are a bit of a mystery. Having seen a mathematical formula to determine how many watts you need to fly a given model, I find it confusing to see the motors rated in kV. Further study shows a range of voltage the motor can handle, as well as a range of amps. So, one can figure out watts.
Then come other questions that might seem like a no-brainer, but for the newbie it might be important. Like, if I have a .25 (IC) sized model, Ringmaster, Flite Streak, etc., can I invest in a .35 equivalent electric package for use in a larger plane, but use it in the smaller plane as well. I would think that you could easily dampen the performance by downsizing the prop and dialing in a few less RPMs. There would be a weight penalty, but for someone just getting into it perhaps it would be more economical to buy one 'system'.
Most forums have a sticky at the top of the page for FAQs such as this, to help newbies such as me to get those repeated questions covered in one easy to find spot. Since the idiot's guide has already been covered, perhaps someone could start a sticky called Electric Control Line for Dummies. I for one would appreciate it. Compatability charts, equivalent power charts, Pro's and Con's of each piece of equipment, and idiosyncrasies, considerations, or characteristics of these items.
Thanks for allowing me to rant.
Offline John Rist
Re: too much info
« Reply #7 on: July 28, 2013, 09:04:47 PM »
When I first got into electric what I looked for in a motor was one that would swing the same size prop at the same RPMs as the nitro burner I was replacing.  That approach worked for me.  I did have the advantage of understanding batteries and chargers.  I have had less trouble getting electrics to run then I ever had with nitro.  I still have trouble getting a 2 cycle nitro run right.  I have had better luck with 4 cycle runs (scale).  The bottom line is electric is no harder than nitro.  I will admit a burn out (up) of an electric can be expensive.  but my last venture with nitro destroyed an airplane when it would quit every time I went inverted.  My advice is to stick with whatever works for you.  If you are just starting out learn electric.  It is the wave of the future.  As with any new sport read all you can and read some more.
 D>K
Offline Larry Renger
Re: too much info
« Reply #8 on: July 28, 2013, 09:23:04 PM »
I was an active participant when Andy and I burned up that system.  Up 'til then, we thought, we're engineers, what can go wrong.  If you understand the e-I-r diagram, you got it all, right?
Dang, reality trumps theory once again!  HB~>
Re: too much info
« Reply #9 on: July 29, 2013, 12:23:11 AM »
All permanent magnet motors have magnets and coils; the coils make electromagnets that work against the permanent magnets to generate torque.
All the brushless motors that we use attach the magnets to the stationary part, that gets bolted to the airframe.  The magnets are attached to the part that rotates.
Inrunners put the magnets inside and the coils outside.
Outrunners put the magnets outside and the coils inside.
I need pictures, but don't have 'em -- sorry.
You understand volts, watts and amps.  Good.
You need the kV rating of the motor in addition to the rated current and voltage.  Basically, the kV tells you how fast the motor will spin for a given voltage, in RPM per volt.  Put one volt on a 1000 RPM/volt motor, and it'll go 1000 RPM (more or less - ratings never tell the whole story).  Generally, the higher the kV the fewer batteries you need, but the more current the motor will pull to generate the same power.
Again generally, two motors that are otherwise identical but have different windings will weigh the same, turn the same speed, produce the same power, use the same power and otherwise act the same, but the one with fewer windings (with thicker wire) will have a higher kV and will use fewer volts (and more amps) to do the same thing as the one with more windings will do with more volts and fewer amps.
If you have two motors of the same kV rating and different power ratings, then unless the size difference is huge pretty much the only thing you'll change going from the smaller motor to the larger one is weight.  That's assuming the same batteries, ESC, and prop.  You may even gain a bit in efficiency.
The big weight and cost penalty is the batteries -- if you get too much battery then your plane has to lug it around all the time, while if you don't get enough then you get short battery life and possibly flights that are unsatisfactory at the end.
That'd be nice.
Re: too much info
« Reply #10 on: July 29, 2013, 10:26:11 AM »
Tim, I think you might have been in a hurry when you wrote the above.
Offline Dean Pappas
Re: too much info
« Reply #11 on: July 30, 2013, 07:33:23 AM »
Most forums have a sticky at the top of the page for FAQs such as this, to help newbies such as me to get those repeated questions covered in one easy to find spot. Since the idiot's guide has already been covered, perhaps someone could start a sticky called Electric Control Line for Dummies. I for one would appreciate it. Compatability charts, equivalent power charts, Pro's and Con's of each piece of equipment, and idiosyncrasies, considerations, or characteristics of these items ...
message received.
  Dean P.
Dean Pappas
Re: too much info
« Reply #12 on: July 30, 2013, 07:56:28 AM »
I didn't feel I stated it well.
Hasn't someone written a guide to electric flight for Stunt News or some such?
Re: too much info
« Reply #13 on: July 31, 2013, 10:06:40 AM »
Tim,
I think we sometimes make things sound more complicated then they are or need to be. When I started in ECL about 2 years ago, I started reading this forum and I asked what was a good starting point. Well at the time it seemed no one could just say what motor, ESC, timer and battery to use for a particular size ship. I was asked all kinds of questions and told it all depends on X Y Z etc. I didn't buy this and decided to take advantage of the "list your setup" area.
I copied Bob Hunts Genesis package except I originally used an A123 pack because I wasn't sure about the safety of the Lipo's. I call Bob and found that if you are just starting using the "fixed rpm" mode in the Castle 45 ESP to set the rpm,  use the timer (a Zrton II) it to control the flight time only was pretty straight forward. Granted as you get into it you can play with the power curves and timing etc. But for just starting this gave you the equivalent of a very good upright Fox 35, 10x6 prop, 4oz uniflow tank, 5% Super Fuel set-up (I know there are better engines than the Fox but this is an example of a typical setup that works well without an in-depth knowledge of details).
As I flew and read more I picked up the lingo and terms and start changing out stuff to make it more like a good tuned pipe. I still fly the simple setup on some ships as it is as good or better then most IC setups.
Best,        DennisT
Re: too much info
« Reply #14 on: July 31, 2013, 11:35:20 AM »
Tim,
I think you're right.
I think there's another factor, though.  This comes from a comment on the Hip Pocket Aeronautics site.  Basically, with electric you can stray a lot farther from the optimum setup and still have something that's plenty good than you can with glow.  The only really hard limits are the minimum battery size and the mininum ESC size, and after your plane poops out in flight or your ESC burns up, they're pretty easy to recognize and fix.  This as opposed to glow power (whose learning curve I'm currently climbing, with much huffing and puffing) where pretty much everything that you can do to an engine can make or break your ability to get a decent run.
So folks that are used to glow power feel like they have to understand every little nudge and wiggle before they can get a good run, because that's what you have to do with glow -- and they really don't.  Getting all the little stuff right will make your electric setup better, but there's a lot fewer things that are really make or break.
Offline Duke.Johnson
Re: too much info
« Reply #15 on: July 31, 2013, 12:05:09 PM »
Bob Hunt sent the "Rudy Taube’s electric cookbook:" to me. I have not read through it completely, but maybe it can be made a sticky if it meets approval.
Offline John Cralley
Re: too much info
« Reply #16 on: July 31, 2013, 12:59:48 PM »
Norm's Cookbook was here but Sparky moved it to here: http://stunthanger.com/smf/index.php?topic=20342.0
John Cralley
AMA 52183
Central Illinois
Re: too much info
« Reply #17 on: July 31, 2013, 01:16:38 PM »
For a new flier (or even a convert's first venture in ECL) would be to start with a Brodak Super Clown package. That will get them going and then they can get crazy into it like the rest of us.
Best,      DennisT
Re: too much info
« Reply #18 on: July 31, 2013, 01:51:24 PM »
I think Larry's ET-1 was the easiest way to get into ECL.  It's cheap, easy and you can use it to traine kids.  That being said. I understand what Paul's friend is saying about infromation overload.
