  • July 31, 2025, 12:13:06 PM
Author Topic: Timer setup tool  (Read 1462 times)
Offline Paul Allen
Timer setup tool
« on: November 08, 2009, 01:19:34 PM »
Is there an article or post on Will Moore's timer setup tool
in Stunt News or alike,I found the picture here on the JMP2
post.
 y1
Offline Will Moore
Re: Timer setup tool
« Reply #1 on: November 08, 2009, 04:31:32 PM »
Paul;
I don't remember what issue of Stunt News I published info on the board,
but I'll try to find the article on my other computer and send it to you via E-mail
Might take me awhile to find it.   Someone here might beat me to the punch
Will Moore
Couldn't find article, but here is picture of the timing board.
You connect the JMP per instructions when using a servo readout.   And then follow
the directions to calibrate the JMP timer.  If you have any questions
I can answer them here.
W. Moore
« Last Edit: November 08, 2009, 05:34:58 PM by Will Moore »
Things take longer to happen than you think they will,
Then they happen much faster than you thought they could.
 AMA # 209
Offline Paul Allen
« Reply #2 on: November 08, 2009, 05:04:44 PM »
Will
    Thank you.
Offline Mike Palko
« Reply #3 on: November 09, 2009, 04:56:57 PM »
I wrote an article for CLW in 2009 (July issue?) that mentioned several ways to program timers. Will's method was covered in that issue.
Offline Will Hubin
« Reply #4 on: November 17, 2009, 10:09:07 AM »
Another option is using a pulse-width measuring instrument such as an oscilloscope, or the poor man's oscilloscope (PM-1) which measures pulses from well outside the nominal 1.0 to 2.0 ms range and displays them on a liquid crystal display. I have used it with the JMP.
Offline Paul Allen
« Reply #5 on: November 17, 2009, 02:09:06 PM »
Set up tool made as per Will's,worked, no problems.
Thanks to all you fellow modellers who have helped
with info on all parts of the electric setup.
System ran on the test bench yesterday,a big thankyou
to Alan Hahn,he has taken time to explain a lot of the
electric system to me.
Paul Allen
Australia
