  • July 11, 2025, 04:37:49 AM
Author Topic: Timer Settings  (Read 1303 times)
Offline Guilherme Souza
Timer Settings
« on: May 15, 2014, 12:33:25 AM »
Dear All
I have the E-Flite 32 , 2450 mAh 5S batterys , will Hubin Timer and 13x4.5 EP prop
But my ESC is a Turnygy Super Brain 80 A
My problen is : IN Will Hubin Timer which one esc configuration I must choose ?
Today I'm using Phoenix New High
Should I use onether ?
This esc has usb linker so the governor mode is active in High
Fast Start (but is too slow yet) .
I'm using 8 MHz , i try to use 12 but the start was slower than before
Some one could help me ?
Thank you
Guil
Offline Bob Hudak
Re: Timer Settings
« Reply #1 on: May 15, 2014, 09:52:33 AM »
 I had this issue with a budget esc also and cured it by using throttle mode on the timer. Reread Will Hubins instruction manual.
Bob
« Last Edit: May 15, 2014, 01:22:44 PM by Bob Hudak »
350838
Offline William DeMauro
Re: Timer Settings
« Reply #2 on: May 15, 2014, 11:49:34 AM »
You may want to try throttle mode or compensation throttle. I played around with some Turnigy ESC's and found that NONE of the governed very well. If I used compensation mode I could get it to run barely ok, which was not good enough for me. Since you already spent your money on the Hubin system, maybe you should think about getting a PHX 60, Ice lite 75 or a PHX Edge Lite 75. They come up often on the RC boards and E bay, if you don't mind a used one for less.
AMA 98010
