  • August 02, 2025, 01:04:31 AM
Author Topic: Thunder Power 4 unit Charger  (Read 3023 times)
Online John Rist
« on: December 27, 2017, 07:02:56 PM »
It looks like I may get to go flying tomorrow.  So I fired up my new Thunder Power charger for the first time and charged up my 4 TP 4C 2800 mah batteries.  All 4 batteries were in different states of charge.  One was almost full.  I had charged it and used it to reset the RPMs on my e-Cavalier.  Two were in storage level and the fourth was somewhere in-between.  The TP4X610HV charger is truly 4 separate chargers built into one case.  Each charger is rated at 100W for a total of 400W.  It has a 115 V power supply built in, (also has a 12VDC input).  I set up all 4 channels for 4 cells, 6 amp, balance mode.  15V x 6A = 90 W.  This stays below the 100W max and provides around a 2X charge rate.  Because it is 4 separate chargers you can record the put-back for each battery.  I did looked at the put-back but did not record it.  However I do remember that all 4 put-back numbers were different.  When done I measured the individual cell voltage of each cell.  They were as follows:  Battery #1: 4.19, 4.20, 4.20, 4.20.  Battery #2: 4.20, 4.21, 4.19, 4.20.  Battery #3: 4.20, 4.20, 4.19, 4.20.  Battery #4: 4.20, 4.20, 4.19, 4.20.   So it appears that the TP4X610HV charger does a really good job of balancing.
I am going to love this charger.  It appears to be a good deal in every respect.    #^   #^   #^
Offline Target
  • C/L Addict
Re: Thunder Power 4 unit Charger
« Reply #1 on: December 28, 2017, 09:26:08 AM »
I love my non Thunder Power 4x80w charger.
Especially for me, when flying rc sailplanes, I can charge 2 contest 2s LiFe  planes, my 8s NiMH transmitter, and a fun fly 1s LiPo DLG plane or something else, simultaneously. It saves a lot of time.
And it is great for 4 batteries for control line as well.
A good investment.
Be careful if you use all different types of batteries as i do. Although the chargers all have alarms, it's easy to make a mistake.
R,
Target
Chris
AMA 5956
Offline Fredvon4
  • Central Texas
« Reply #2 on: December 28, 2017, 11:15:47 AM »
I do not play electric airplane right now but when I first came back to the hobby got deep into R/C
In this hobby we have all sorts of batteries that need charging
MY original Thunder Dual power RC 680 is 5 years old....never needed flashed to update firmware ...and does a very good job of recharging all my variety of batteries... mostly all my PB Nimh, Lipo, and Nicd stuff
At the time I was learning....all the club snobs/experts we steering me to $150 to $300 chargers.... this $65 bugger does all I need
So basically as I consider one or more Electrickery power solutions for my hobby---- I am glad the brand is still good and as an upgrade may NOT break the bank as part of my cost benefit decision process
Fred von Gortler IV
Offline Mike Anderson
« Reply #3 on: January 03, 2018, 01:48:50 PM »
Never mind - I was asking about a feature that is mentioned in the instructions, but has apparently not been implemented (or kept) in this charger.
« Last Edit: January 03, 2018, 04:03:19 PM by Mike Anderson »
Mike@   AMA 10086
Central Iowa
Online John Rist
« Reply #4 on: January 03, 2018, 04:13:13 PM »
John -
Was wondering if you downloaded the software package for this charger.  It is mentioned in the instruction manual, but I don't find it on the ThunderPower site.  Nor the instruction manual.  Just curious -
I missed that part in the manual.  Mine  jumped and worked when I turned it on.  Haven't looked to see what is settable other than battery type, number of cells, and charge level.   So far the default setting for the balance mode have worked for me.  I looked and I don't see a data port for software update.
Online John Rist
« Reply #5 on: January 03, 2018, 08:27:16 PM »
I read the instruction book.  It does make mention of some kind of software down load for a PC.  It also talks of the need for a USB cable.  I looked once again and I can not find a USB port.   There are 4 each 3 pin ports across the front that are not labeled or mentioned in the instruction book.  I suspect they are part of the factory test/setup.  I looked at the Thunder Power web sight and found no down loads.   Another point of mystery is the temperature ports.   Back in the good old days the top line NiCad chargers had temperature probes to detect full charge.  A NiCad battery has a sharp temp rise once full.  The manual talks about the temperature ports but Thunder Power does not offer, for sale, temperature probes.  To me it looks like Thunder Power is re-branding an existing power supply but is not supporting all of it's features.   Having said this I don't care.  So far it does everything I could ever want.   y1   y1   y1
