  • July 17, 2025, 09:31:35 AM
Author Topic: Thunder Power 2800mA Prolite X series  (Read 1722 times)
Offline Rogerio Fiorotti
    • Control Line by Fiorotti
« on: February 19, 2018, 08:52:23 AM »
I dismounted a Thunder Power Pack 2800mA - 5S the cells are 2700mA.
The reason for the disassembly was that a pack detected a defect in a cell after 60 cycles so it turned to 4S.
Someone knew this information?
Offline John Rist
Re: Thunder Power 2800mA Prolite X series
« Reply #1 on: February 19, 2018, 12:26:05 PM »
I would bet TP knows what they are doing.   The marking on the cell may be some kind of a minimum.  TP stands behind their products so I wouldn't give it a second thought.  As I understand it TP tests and matches cells in a pack so all is good in the land!   y1
« Reply #2 on: February 19, 2018, 12:37:15 PM »
Looks like they were over rated. I guess my 6s is the same? If you use cigarette lighter fluid or naptha it will melt the glue between batteries so you can gently wedge them apart.
I use fishing wire (nylon) ..
Rogerio.
« Reply #3 on: February 19, 2018, 03:01:46 PM »
Well, that's very interesting..  As I went from the older G-8 Prolite 2700ma to the Prolite +  Just late last year, and was a little surprise the reserves capacity it has.  It went from a typical 14-18% end of flight discharge to 21%-24%.  which I have never seen 24% with the same set up when the G-8 batt was new.  maybe the 2700ma is really 2800ma.
Online Fred Underwood
« Reply #4 on: February 20, 2018, 04:20:33 PM »
About a month ago, I decommissioned a battery, TP 2800 6s.  Yep, the cells said 2700 on the side.  If memory serves, I had some 2700s,(not G8) before the newer 2800s.    My understanding was a cell internal change when the G8s stopped, part of the ongoing cell improvement, and/or production cost.
My guess is that some ideal test data will show the 2800 mah claimed, more thoughts here on the older capacity thread
https://stunthanger.com/smf/gettin-all-amp'ed-up!/calculated-or-stated-battery-capacity/msg512374/#new
Fred
352575
