  • June 14, 2025, 12:57:49 PM
Author Topic: mashed up monster  (Read 699 times)
mashed up monster
« on: October 27, 2011, 02:35:48 PM »
in the main forum I explained why - but this is a cobbled together model for a comp tomorrow..
Scorpion 3026-890 - 13 x 5.5 pusher - ICE lite 50 - Hubin FM9-V timer
not sure if I am going to run it is governor or set RPM - or if I should change to 5s packs form 4s........
not sure what it weighs - finished it last night at 11:30......
Offline William DeMauro
Re: mashed up monster
« Reply #1 on: October 27, 2011, 02:45:43 PM »
If you run the 3026-890 stay with 4s packs. That motor is KV matched for a 4 s with that prop. Thats my SV22 setup.
AMA 98010
« Reply #2 on: October 27, 2011, 03:55:35 PM »
thanks Will - do you run set RPM?
I was flying the legacy in governor high around 10k.......but with the 4.5 pitch pusher - was thinking 9500 with the 5.5?
