  • June 15, 2025, 06:48:43 PM
Author Topic: E-PT19 - now RTF  (Read 1906 times)
E-PT19 - now RTF
« on: May 13, 2009, 10:24:41 PM »
Another work in process, while I wait for the wind, storms, wind, cold, and wind to abate a little.  At this rate I will have 4-5 brand new E-birds to test - EGAD!
This is a Hanger 9 PT-19 Profile that I am converting to try some of the Horizon stuff including the Eflte Power 15 motor, Eflite ESC, Eflite CL Timer and 4Sx2600 ThunderPower battery.
Word on the slimer PT's is that they tend to be a little tail heavy, so I tried pushing everything forward.  Motor is centered on the fuselage and mounted on 1/16" x 1/2" x 3/4" aluminum angle brackets made from stock found at the local ACE hardware.  The mount is light, very robust - and probably a pretty good layout to use for most profiles.
Just about all the special ECL work is done, from here out it will build just like a normal ARF...
« Last Edit: May 16, 2009, 04:55:43 PM by Dennis Adamisin »
Offline andreas johansson
  • SWE-56998
Re: E-PT19
« Reply #1 on: May 14, 2009, 12:15:43 AM »
Very nice Dennis :) Are you using a I.C prop?
Andreas
Nobler-O-Maniac
SWE 56998
Re: E-PT19
« Reply #2 on: May 14, 2009, 05:52:59 AM »
Thank you Andreas.  BW@  The IC prop is just for handling around the shop.  Electric props are so thin & light I would hate to damage it just in building and handling.
The PT-19 is a small bird, (around 500 sq in) I am planning on using a 10x5 APC-E.
Online Crist Rigotti
Re: E-PT19
« Reply #3 on: May 14, 2009, 06:47:15 AM »
Dennis,
I see you're keeping busy!  Looks like a neat project.  I'll know when you finally get to go flying, the there'll be a dip in the power grid!  LL~
Re: E-PT19
« Reply #4 on: May 14, 2009, 07:09:25 AM »
Thanks Crist.  I figure you must have close to a 100 flight head start.  Gonna take a lot of "resolve" for the rest of us to catch up!
Got another piece of good news, my club build a new PAVED circle over in Kalamazoo, about 40 miles away.  That will be a big enabler for birds like the Swinger...
Re: E-PT19
« Reply #5 on: May 14, 2009, 08:11:46 AM »
That is good news!  My circle is about 60 miles away.  Keep us posted on all your birds.
Dave Adamisin
Re: E-PT19
« Reply #6 on: May 14, 2009, 04:12:50 PM »
I don't know guys, we took away his crimping pliers and hid his soldering iron but he just keeps cranking them out........
Offline William DeMauro
Re: E-PT19
« Reply #7 on: May 14, 2009, 05:15:01 PM »
Dennis,
 Good choice for an ARF glow to E conversion. I flew Neil Beekmans a few months ago and my first thoughts were that that plane would be perfect as an electric. He had to replace the fuse with a standard fuse cause he busted the original on a landing. He feels the fuses are weak. I am sure they are strong enough for an E setup.
 As far as Crist goes, we will never catch up to him, I am only up to flight #11 on my new one and while warm enough its either raining or windy here. I don't even have to travel that far to get to Flushing Meadow Park (about 6 miles) and I cant get any flights!!!
AMA 98010
Re: E-PT19
« Reply #8 on: May 14, 2009, 08:51:06 PM »
Well......I just put on the 50th flight on the Resolve EP tonight.
Re: E-PT19 - now RTF
« Reply #9 on: May 16, 2009, 04:58:06 PM »
Ya know, when you are unemployed, the weather is crappy, & and mama is out of the house, these ARF's go together PDQ!
« Reply #10 on: May 16, 2009, 06:03:05 PM »
Getting there!  Going flying Sunday?
Offline Warren Allred
« Reply #11 on: December 07, 2009, 11:38:00 AM »
This thread seems to have died out...
How is it flying Dennis?
-- Warren in Missouri
AMA 19909
LSF 8170 Lvl V
« Reply #12 on: December 07, 2009, 03:52:19 PM »
Hi Warren
Still have not flown it a lot, so it is not wrung out.  Looks promising tho.  I did not like the original Horizon timer so I fited it with a Will Hubin FM-0c.  The ESC requires a low throttle setting to arm - so the RPM pot must be re-set for every flight.
I saw the parts list you have for your PT-electric - I'd say you  will succeed using those pieces,  You are in San Diego(?) so you will probably have yours trimmed out and flying great before I get a change to fly again!
« Reply #13 on: December 07, 2009, 04:00:27 PM »
Thanks Dennis!  H^^
AMA 19909
LSF 8170 Lvl V
