  • July 19, 2025, 03:16:19 PM
Author Topic: Third question for Christ Rigotti  (Read 1247 times)
Offline petermick
« on: January 19, 2018, 09:53:31 AM »
Hi Christ, it's me again.  Where did you find the 3 mm x 8mm screws?  I went to Ace Hardware and True Value Hardware and neither has anything smaller than 4 x 10.  Also what is the thickness of the ply motor mount material you used.
If you want send your reply to my e-mail at pmick82541@aol.com.
Peter Mick
Online Crist Rigotti
Re: Third question for Christ Rigotti
« Reply #1 on: January 19, 2018, 12:07:42 PM »
Peter Mick
Pete,
The motor mount is made from 3/16" Birch ply.  For the screws, perhaps 3x10mm would be a little better.  Be sure to use a washer under the head.
I think you can get them from Dubro #2123.  Washers are #2109
Offline John Rist
« Reply #2 on: January 19, 2018, 01:32:13 PM »
https://www.mcmaster.com/   Mcmaster-Carr has metric screws.  3mm   https://www.mcmaster.com/#standard-socket-head-screws/=1b75rp9   Click on size on the left of the screen,  then type
Offline eric rule
« Reply #3 on: January 19, 2018, 04:42:39 PM »
Standard stock item at RSM Distribution.com Available in high alloy steel socket head M3 from 6mm through 40 mm. Stainless Steel socket head in M3 from 6mm through 40mm. Also available in socket flat head and socket button head.
 See our web site www.rsmdistribution.com (under the "Building Supplies" section - "Hardware" sub section.
Offline petermick
« Reply #4 on: January 20, 2018, 09:21:34 AM »
Hi Guys
As always, thanks for the responses.  They are always helpful.
Pete
