Electric Stunt => Gettin all AMP'ed up! => Topic started by: petermick on January 19, 2018, 09:53:31 AM
Hi Christ, it's me again. Where did you find the 3 mm x 8mm screws? I went to Ace Hardware and True Value Hardware and neither has anything smaller than 4 x 10. Also what is the thickness of the ply motor mount material you used.
If you want send your reply to my e-mail at pmick82541@aol.com.
Peter Mick
Peter Mick
Pete,
The motor mount is made from 3/16" Birch ply. For the screws, perhaps 3x10mm would be a little better. Be sure to use a washer under the head.
I think you can get them from Dubro #2123. Washers are #2109
https://www.mcmaster.com/ Mcmaster-Carr has metric screws. 3mm https://www.mcmaster.com/#standard-socket-head-screws/=1b75rp9 Click on size on the left of the screen, then type
Standard stock item at RSM Distribution.com Available in high alloy steel socket head M3 from 6mm through 40 mm. Stainless Steel socket head in M3 from 6mm through 40mm. Also available in socket flat head and socket button head.
See our web site www.rsmdistribution.com (under the "Building Supplies" section - "Hardware" sub section.
Hi Guys
As always, thanks for the responses. They are always helpful.
Pete
