  • July 17, 2025, 09:13:13 PM
Author Topic: The way back machine  (Read 1015 times)
Offline Armand Ciuffo
« on: July 31, 2013, 06:04:27 AM »
Started modeling in the 50's with CL, had the Ringmaster JR, Ringmaster, and Ringmaster Sr.
Left modeling till the late 70's and have been in Electric RC since. Want to get back to my "roots".
Thinking about Pat King's Ringmaster Trainer IIE and RSM's Electric Glow equivalent .35-.40 package.
Have a bunch of questions, but for now;
What length lines should I use.
Offline John Rist
Re: The way back machine
« Reply #1 on: July 31, 2013, 10:46:29 AM »
Sounds like pretty close to a standard Ringmaster in size.  I am guessing 55' to 60' limes.  Any U-control ship in the 35 motor class should work on 60' lines.  .012 dia lines should work.  Smaller are hard to handle.  Larger have to much drag.  Beings you are going electric you may want to consider an RC throttle.  This would allow you to stop flying if things go wrong.  Sounds like you already have the RC radio and know how to hook it up. Hang the Tx on your belt and work the stick with your left hand.  Or you can have an assistant work the throttle.  Electric is quite so you can easily talk to a helper on the side line
Welcome back from the dark side of RC.  I too went RC for years and am now back.
« Reply #2 on: July 31, 2013, 12:09:46 PM »
Thanks for the info.
That is what I was going to do, have a small TX from a micro plane and micro rx, but am wondering if this might be a better idea:
 The KR Governor Timer Ver.2
« Reply #3 on: July 31, 2013, 12:34:23 PM »
There's two nice things about using an RC throttle: stopping when you get dizzy, and touch & go landings.  Neither of these are provided by a timer.  Neither are necessary (or allowed) in competition stunt, but for sport flying they're kinda fun.
Offline John Cralley
« Reply #4 on: July 31, 2013, 12:45:26 PM »
Check the "List Your Setup" at the top of this forum (replies # 36, 59, & 81). If you use an RC throttle you can skip the timer but you will probably want to use a timer after you get your "control line sea legs back."
Sixty foot lines are fine.
Package deals will be easier but will cost significantly more.  y1
John Cralley
AMA 52183
Central Illinois
Offline John Rist
« Reply #5 on: July 31, 2013, 03:37:29 PM »
I have one of the KR Governor Timers and I love it.  Coupled with a cheep speed controller it provides a bullet proof setup.  No burnouts if you hang the prop on take off.  However if you have the RC setup I would start with it.  It is an easy swap over when ready for a timer.  You will out grow the trainer in a hurry and be looking for an airplane that does the full stunt pattern.
Offline Larry Renger
« Reply #6 on: August 02, 2013, 08:47:47 PM »
Package deals will be easier but will cost significantly more. -Quote from above
In Andy's H^^ and my experience, a system that is coordinated and works off the shelf is the cheap way to go, no matter the cost!
