  • June 19, 2025, 11:49:27 PM
Author Topic: Laser cut ET-1 !  (Read 862 times)
Online Larry Renger
Laser cut ET-1 !
« on: February 14, 2013, 08:55:46 AM »
At the KOTRC club meeting, Eric Rule showed the laser cut parts for the ET-1 kit.  WOW!  The coroplast cuts beautifully.  No way you could match it by hand.   #^
Offline Duke.Johnson
Re: Laser cut ET-1 !
« Reply #1 on: February 14, 2013, 09:21:52 AM »
pictures are worth a thousand words. it's show and tell time I think.
Online Larry Renger
« Reply #2 on: February 15, 2013, 09:31:14 AM »
Pictures of the planes are available in other threads about it.  Do a search. Or if you want a photo of the cut edge, there is nothing to see, it is just a perfectly cut edge, no distortion.
Offline Dean Pappas
« Reply #3 on: February 15, 2013, 11:43:31 AM »
Hi Larry,
That clean, eh?
That's good to know.
thanks,
  Dean P.
Dean Pappas
Offline Keith Renecle
« Reply #4 on: February 15, 2013, 10:27:30 PM »
Hi Larry,
Thanks for that. I was also curious about the edges. I thought that the laser would burn the plastic and  the edges would be rough. I know that water-jet cutters do a real good job with coroplast and you can stack the sheets up and blast through a pile of them as well.
Keith R
Keith R
