Electric Stunt => Gettin all AMP'ed up! => Topic started by: Dennis Toth on October 05, 2009, 07:40:37 PM
Guys,
I have an old hanger queen Stuka that I'd like to convert to E-power. This ship is around 40" span and with a 26 -4 stroke weighed in at 36oz dry. It flys well with a 9x6 to 10x5 prop. I'd like to get a power package in around 11oz. Looking at the available motors I think the new AXI 2814/16 @ 1035Kv, 3.7oz, coupled with a 4s1p 2100 mah pack about 7oz, would meet the weight mark. Question, is the 2814/16 a good motor for this size ship and will it make the 5 min, 20 sec flight time with the 2100 mahs?
Best, DennisT
Guys,
Best, DennisT
Well that's the battery I use in both my Vector and Nobler planes. I would think it would be ok for your plane.
I might go to a slightly lower kV (900 range if you can find one) to better match the 4s pack. Also I would consider the APC TE 11x5.5" prop.
What rpm are you thinking of running? that sort of sets the rpm (and the kV of the motor).
Alan,
I was going to use 9000 - 9500rpm as the start point with the 5" pitch and 60" lines eye to eye. Target lap time is 4.9sec.
Best, DennisT
If you plan to stay with a 10" prop, then to be safe, I would stick with the kV=1035rpm/V. That should give you plenty of headway to select rpm.
With my Nobler, the lowest voltage from the 4s2100mAHr pack during a flight was 13.8V, during the overhead 8 maneuver. So with a kV of 1000 rpm/V, that would translate to an unloaded rpm of 13800. With a 10" prop, I am guessing you may need 10krpm to keep the tension ok at that stage, and 10k/13.8k is 72%, so I think you will be fine--especially if you need less rpm (and I have already derated the pack from the average 14.8V that most of us use in the "70%" rule.
If there is an issue, the 11" prop would need less rpm (assuming nominal pitch is about the same), so you could always rely on that.
