  • June 19, 2025, 04:34:59 AM
Author Topic: 3 bladed pusher spinner  (Read 1323 times)
Offline Russell Bond
  • Bandolero
« on: May 29, 2013, 07:33:52 PM »
Hi all,
I would like to buy a 2" 3 bladed pusher spinner.
Does anybody know where I can buy a relatively cheap one as I am trying out a 3 bladed pusher prop and don't want to spend a huge amount on a spinner that I may only use once.
I normally use the Tru-Turn spinners that are great. However they are a bit too expensive for this application.
Bandolero
Re: 3 bladed pusher spinner
« Reply #1 on: May 29, 2013, 08:14:06 PM »
If you can make a suitable CAD drawing, I can get it printed out of ABS.
« Reply #2 on: May 29, 2013, 08:33:19 PM »
Wow, Howard has connections. I may have to talk to him about that. After I get Pat Johnston to do the CAD.
« Reply #3 on: May 29, 2013, 08:51:33 PM »
Pat has more important things to do.  Maybe I can do it.  Call me.
Offline James Strickland
« Reply #4 on: May 29, 2013, 11:58:20 PM »
So Russell, Where do ya get 3 blade pusher props?
TIA, James
  • Bandolero
« Reply #5 on: May 30, 2013, 12:56:57 AM »
Never you mind.............................. n1
I knew someone would get wise and ask me that question...................... S?P
OK, it's Barry Robinson in the UK.
I'm going to try a couple out that he has made.  ;D
Bandolero
« Reply #6 on: May 30, 2013, 06:45:49 PM »
Cool.
Offline paul winter
« Reply #7 on: June 05, 2013, 11:55:24 AM »
i fly on Barry,s props and there great ,there is pictures on an earlier thread
paul
Offline Colin Collyer
« Reply #8 on: June 06, 2013, 02:15:24 AM »
I'm looking for 2 inch 2 blade reverce pitch spinners... or ones with no prop cut out.
 Where do I start looking ?
Offline jim welch
« Reply #9 on: June 06, 2013, 07:59:42 PM »
MPI  pro spin stock nr psr50r 50mm elec spinner reverse cut 2 inch maxx products inc lake zurich il 60047   5mm  shaft cnc spinner  22.00 dollars...beautiful workmanship..I got 8 of them when I seen the workmanship on the product it was exceptional at a great price...jim ( this is in answer to collin's question on the 2 blade reverse cut 2 inch spinner.)
« Last Edit: June 06, 2013, 08:21:47 PM by jim welch »
AMA 89335
